I'm troubleshooting a Samsung LS28D590DS 28" 4K monitor which has white vertical banding in the center of the LCD panel. The image looks like it's distorted slightly as well in the middle. Am wondering if this could be caused by the panel, t-con board or the main board?
Samsung 4K LCD white vertical banding in center
Re: Samsung 4K LCD white vertical banding in center
White image when only the t-con board is connected to the panel. When the mainboard is connected, there's also a bit of 'double image' on the left side of the screen with the moving check signal cable popup. It's clear on the other side of the screen.
