Hello everyone!
I used this enclosure for at least 4 years until one day its PSU went kaputt. It didn't work anymore at all, not even the led would come on, and after trying to adapt another one to the strange pinout that the plug used I opened the case to find this.
It's very similar to this one: https://www.badcaps.net/forum/showthread.php?t=7065
The fuse tripped (luckily) and the capacitors on the output side seem on their way to capacitor heaven (or hell.)
Well, let's see what we have here:
Hot input side:
1x Yalecon RX 400v 47uF CE, visually good
1x Wanlong (no series) 35v 100uF no-vent, visually good
Cold output side
3x Wanlong (no series) 16v 1000uF, 2 of which domed and bent, with bottom domed also; the other one looks OK.
1x Wanlong (no series) 25v 470uF, visually good.
I think it would be good to replace all those capacitors and the fuse, moreover I have to resolder the three wires going to the plug as while trying to adapt another similar one I had to cut those.
Which would be good replacements for those? Should I replace all of those capacitors? Other suggestions? A good way to resolder the wires?
PS: I never understood why the traces on these PSU PCBs are always covered with solder all the way unlike on motherboards and there is usually very little solder resist... any clue?
Pics attached
Hot input side:
Cold output side
Pics attached
