These are Sacon FZs right? *sigh*
    Re: These are Sacon FZs right? *sigh*
    Originally posted by PCBONEZ View Post
    Dunno, but don't think so based on what people have tried that worked.
    I don't do anything that is demanding on video so I get low end cards from Jaton.
    Jaton uses mostly Samxon and Sanyo caps.
    They just work.
    I'll give it a shot...Again if it doesn't work...I have a spare 6200 in another computer that has integrated graphics. But I also could just buy a 6200 on eBay for $20.
    Jaton gives me the chills...but I guess they work, so oh well.
    I use a HD4650 on my main computer. I also don't do too much demanding. It was a $50 card.
      Not discrediting you...just wondering if someone else had any input on the ESR matter. I think I'll do it, but if it seems way off, then I'll stick to something else I guess.
        1/3 of a dollar is a lot different than 1/3 of a penny.
        It's .015 different.
        On ESR meter
        .007 shows .01
        .022 shows .02
        Besides which, looking at the card, the caps are all either in a VRM type VR circuit or one with no associated inductor.
        [Yeah I found photos of the card before I posted that...]
        Mann-Made Global Warming.
        - Dr Seuss
          On ESR meter
          .007 shows .01
          .022 shows .02
          So polymers are still in the clear? Not that much of a difference I guess.
            My first GeForce (GeForce 2 MX) (Received on October 5, 2001) was a Jaton and the heatsink seemed to actually be better than some of the higher end GPUs!
            It would also work fine as passive. It was full copper (Maybe copper plated.)
            I don't remember if it's a full copper one or not.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            16 GB AData XPG Spectrix D41
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              the polys will be ok.
              you dont need 1000uf there.thats what was used to get the esr desired in a cheap part.
                That and the voltage was bumped up to make the physical size of the cap larger, and therefore lower ESR.
                I could try downgrading the capacitance on the polymers, but the newer polymer series ESR are so damn low, I would have to go down to like 220uF to get 20mOhm...which I think is a bit too low.
                I'll keep the 1000uF I guess then. Maybe 820uF.
                  Originally posted by TheLaw View Post
                  I could try downgrading the capacitance on the polymers.
                  Don't need to.
                  820's might also be cheaper. [higher production size]
                  - Dr Seuss
                    Don't need to.
                    Alrighty then.
                      Finally did the recap.
                      Went with 6x 1000uF 6.3v Nichicon/FPCAP, 1x Chemicon 100uf 10V PS.
                        But does it work??
                        -David VanHorn
                          Originally posted by Agent24 View Post
                          But does it work??
                          Yes very well.
                            Nice!
                            -David VanHorn
