#1 |
CapXon Be Gone
City & State: Idaho
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
![]() So I disappeared from working on electronics for quite some time. I'm unboxing my ancient projects and want to resume some of them. Unfortunately, my knowledge is a little rusty.
I've always liked to do full recaps on power supplies. My cap supply isn't perfect and I do not have any more 0.47µF 50V caps. I do have some ceramic caps with that value. Can they replace the lytic without issues? If I remember correctly, their max voltage drops rapidly after getting hot. Is that correct? If this isn't a good idea, I doubt the cap will cause any problems. It's by the main controller/exhaust so I doubt it will get hot or fail but I like to be thorough. |
#2 |
City & State: Europe
![]() most ceramics are 60% tolerance.
i use polyester or polypropylene for 1uf and under. |
#3 |
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
![]() Ceramic capacitors capacitance are also voltage dependent.
So the general answer to this question would be no, you can't.
"The one who says it cannot be done should never interrupt the one who is doing it." |
#4 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() If you can get same value/voltage CGO ceramics, you won't have to worry about the temperature or voltage coefficients. If X7R, then the combined tolerance will be, IIRC, +/-20%. Z5U and Y5V are crap, IMO.
That said, the impedance characteristic will be very different from lytics.
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 7 5Ks, 1 8K, 8 10Ks, and 4 half marathons |
#5 |
CapXon Be Gone
City & State: Idaho
![]() Thanks for the replies. I couldn't find anything suitable in my parts bin. I think I will just leave the cap where it is. All the other higher value caps will be replaced which should be good enough.
#6 |
![]() Ack! COG, not "CGO".
#7 |
Solder Sloth
City & State: CO
I'm a: Hobbyist Tech
![]() but it is NP0?
#8 |
![]() "COG" and "NPO" are the same thing, probably nomenclature going back more decades than I do (I think I saw the terms used in late 1950s vintage TV technician magazines).
#9 |
Solder Sloth
City & State: CO
![]() oh I was jusr being silly with O's and 0's, you know my username...
#10 |
CapXon Be Gone
City & State: Idaho
![]() I needed to order parts for something else so I just ordered some 0.47µF 50V nichicon UPW
#11 |
#12 |
Solder Sloth
City & State: CO
![]() 000000k it is
#13 |
City & State: New Jersey
![]() If you want to visualize how capacitance drops with applied DC bias voltage, you can check out Kemet's KSIM web app:
https://ksim3.kemet.com/capacitor-simulation The limitation is fundamentally package size, and more directly, the physical amount of dielectric material contained. Since Class II ceramics are ferroelectric, they "saturate" similar to how an inductor's core might. More material means it saturates less under the same DC bias conditions. Beware of "too good to be true" capacitance values in tiny packages. Sure you can get a 1.0uF/25V 0603 capacitor, but you better not use it above 5V, if you really need a 1.0uF capacitor. |
#14 |
CapXon Be Gone
City & State: Idaho
![]() Thanks for the link, that's a pretty useful tool
Thread Tools | |
Display Modes | |
