Dell Inspiron 13 5379, need Bios and EC for MEC1416-NU
    Hello ppl.
    I had a bad MEC1416, which would drain the RTC battery.
    I decided to replace the IC, but now i need the data for the EC so i can boot it, hopefully.
    After replacing the IC i did a dump on the new one and got 194 kB file, but accordingly to the datasheet it should be 160 kB ?
    enyone have a EC dump for the specific model or from same series ?
    I have also attached the dump from BIOS and new MEC.
    Best regards
    Re: Dell Inspiron 13 5379, need EC for MEC1416-NU
    Try
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      Try
      Hello Hoaca.
      i did give it a try but i have run into some troubles with SVOD programmer.
      First issue is a, Boot Block in protected mode, which i dont know if i should ignore ?
      next error is a blank check error:
      Error blanck check in page: 16 byte 0 addr: 1000h
      Blanck checky false
      I might begin to think my SVOD is not supporting MEC1416.
      I will try my TL866-2 Plus.
      Thanks for the EC, i will post when something new happends
        https://www.badcaps.net/forum/showpo...3&postcount=15
          Hey SMDFlea.
          thanks for noting that. what is meant from "main" ? like BIOS or Chipset or other ?
            Hey SMDFlea.
            This means that the data for the EC chip will be shared from the bios. Looks like you need a refreshed bios file.
              succes its trying to start but shutdown after a few sec.
              it was original with water damage, time for some probing.
                DELL 13-5379 EC + bios files
                Hi.
                if you can help me with a "EC" and bios bin file for
                DELL_13-5379
                SL KBL-R A00(ROR) 17810-1
                thanks
                  Re: DELL 13-5379 EC + bios files
                  Originally posted by kuraimangetsu View Post
                  Hi.
                  DELL_13-5379
                  thanks
                  It does not need programming.See post #4
