please help me bios needed original bios i added here
biostar j1800nh2 ver:6.0 bios request
Re: biostar j1800nh2 ver:6.0 bios request
Originally posted by umit View Postplease help me bios needed original bios i added here
Rename from .BSS to .bin if your programmer doesn`t recognise the file extension
Originally posted by SMDFlea View PostDid you look for the bios at the support site https://www.biostar.com.tw/app/es/eo...D=727#download
Originally posted by umit View PostHello, I downloaded it from the site, the content is very different from the original, so it does not work.
Make another backup and compare with the unbooted virgin bios,if both files are still the same the motherboard isn`t posting,the bios isn`t being read or written to.
Originally posted by SMDFlea View PostIts the right bios for the motherboard.It will look different as the TXE firmware hasn`t been initialised until its booted (it will only change if the board is working with no other faults) ,and the NVRAM is not populated until its booted.
:Niye:Originally posted by SMDFlea View Postwhat is there to edit ? ,if the TXE firmware is cleaned and NVRAM cleared it will be the same as the virgin bios,assuming theres no other corruption in your backup,it only takes a few bytes to be bad and you can`t tell just by looking. If the virgin bios hasn`t worked the problem is 100% somewhere else
Originally posted by umit View PostI wrote the cap file that I downloaded, the device did not work, but there is no image in the original bios.Last edited by SMDFlea; 07-07-2022, 09:14 AM.
Originally posted by umit View PostHello, I wrote bios but it didn't work. I added a photo, I showed it in the related volt photo, there is no error, but it did not work
Re: biostar J1800NH2 VER:6.0
Originally posted by umit View PostHello, the motherboard does not start, I have shown the volts in the photo, I really need a working bios, please help, I backed up the original bios.
Desktop PC repairs (Not bios requests or schematic requests) go here: https://www.badcaps.net/forum/forumdisplay.php?f=14
The two parts of the forum are seperate. There is no need to post the same bios request again, i have posted a fully working bios for you.
When you write the bios select the chip manually,do not use auto-detect, the chip part number is etched on top,choose it from the support list. When you have written it it should automatically verify. Read it back again from the chip to make sure it has actually written to it,and compare it with the file i posted using a hex editors file-compare function. I use HxD hex editor,its free and there is a turkish language version.Just open both bios with it then select Analysis -> Data Comparison -> Compare .If they are the same then the bios has been written correctly and the problem is somewhere else.
https://mh-nexus.de/en/hxd/
bios J1800nh2 ver: 6Attached FilesLast edited by SMDFlea; 11-08-2022, 11:33 AM.
