I put a standard password on the BIOS and the laptop does not accept it now. Ok, you can do a reset. I boot from F2, it asks for the password and the ctrl-tab-ctrl-enter key combination does not work. Shows the Not Certified message. Unplugging the BIOS battery did not help, resets the computer did not help, it happens both on the battery and on the AC power. I am in a deadlock, I do not know how to call up the codes needed to unlock. I assume that the password is not kept in the BIOS, so removing the bones and programming with the programmer will not help. The whole problem is that I have the Boot Menu blocked in the BIOS and in the event of an SSD failure, I will not be able to do anything after inserting a new SSD. Can anyone help me? In the laptop is the 3rd generation i5, if it matters, a laptop from the business line
Toshiba B553/J BIOS password problem
