Apple Macbook Air 13 A1496( 820-00165-a) bios
    Re: Apple Macbook Air 13 A1496( 820-00165-a) bios
    Originally posted by simpleway View Post
    this is de cleaned dump
    can you please, clear password from this
    hwc FVHV39RAJ1WK
    FVHV39RAJ1WK
    FV97292006WJ22GAM
      hwc FVHV39RAJ1WK
      FVHV39RAJ1WK
      FV97292006WJ22GAM
      post the original bios here and someone will help you ..
        https://cloud.mail.ru/public/JCjG/4snvhUDKi
          I can not put it here.
          what else is needed ?
          I will be grateful
            A1466
            820-00165-a
            fv9729006wj22gamfca3892181b33b26
              A1466
              820-00165-a
              I will be grateful
                A1466
                820-00165-a
                I will be grateful
                try this
                  Originally posted by crowntoy99 View Post
                  try this
                  my friend is not working correctly. MacOs installation fails. Cannot load
                    try this
                      I'm going to try, thanks for helping
                        try this
                        thank you very much, everything works, many thanks for the responsiveness
                          this one has a pin lock on it if you can clear it for me please thank you cuz nobody elses bios program works i tryed them all....
                            try...
                              check this
                                hi guys, can you help me to unlock this dump from a a1466 emc 3178 original has password, i tried flashing with other dumps but no display, thanks
                                  try..
                                    thanks it worked like a charm! can you please clear password of this backup , thanks a lot
                                      try..
                                        Hi there! I'm having trouble with this 13" MacBook Air. The computer turns on, fan spins, all power rails OK, but no chime, no backlight, etc.
                                        So, I removed the U6100 and soldered one from a non-identical non-donor board, and it works "OK"*, so... The firmware is corrupt.
                                        Does anyone have a clean ME dump for exactly this BIOS (820-00165-A EMC2925, Early 2015 i5)? I can change serial number and write it (got a CH341A).
                                        Thank you!
                                        *OK means the computer turns on, chime, boot extremely low, etc., but works at least...
                                          Thank you!
                                          post the full name and model of the laptop, serial S / N number and bios backup.
