Lenovo V110-15ISK Unlocked BIOS Password
    Dear All
    Need Help to Unlock BIOS Password for Lenovo V110-15ISK, Original BIOS Following attached File
    HTML Code:
    [ATTACH]233974[/ATTACH]
    Last edited by SMDFlea; 04-05-2023, 08:40 AM. Reason: Attachments cleanup,server space low.
    Re: Lenovo V110-15ISK Unlocked BIOS Password
    Originally posted by huss584 View Post
    Dear All
    HTML Code:
    try this..
      Originally posted by peste View Post
      try this..
      Thank You, Done
      [/ATTACH]
        thank you, done
        [/ATTACH]
        dmi 201000-2011ff
          dmi 201000-2011ff
          BUT the Serial # an MTM show me invalid as you see in picture above
            move the DMI information from the bios posted by you. in the bios posted by me ... I passed the interval in which the DMI information is (item # 4) (give your copy-paste), at that interval from one bios to another..use the HxD program ..
              lenovo v110-15isk bios password removal please
              Hi can someone help to remove password please from laptop best wishes
              Last edited by SMDFlea; 04-05-2023, 08:41 AM. Reason: Attachments cleanup,server space low.
                Re: lenovo v110-15isk bios password removal please
                Try with this tool
                https://www.badcaps.net/forum/showthread.php?t=87588
                Become a Badcaps supporter
                Thanks to all supporters.
                  Originally posted by hoaca388 View Post
                  Hi I've tried that . It doesn't like it . I've used that tool loads of times. It comes up with a black screen quickly then goes away
                    try..
                      try..
                      hi many thanks it worked . may i ask what is the tool for opening up the bin file and it shows you all the information of that file ie coa ect . best wishes
                        I combined the original with the update from the Lenovo site..if that's what you asked ..
                          hi is there any chance you can do this one please . this is for same but different laptop
                          best wishes
                          Last edited by SMDFlea; 04-05-2023, 08:42 AM. Reason: Attachments cleanup,server space low.
                            best wishes
                            here
                              Originally posted by SMDFlea View Post
                              here
                              Would it be better to preserve the applicant's original BIOS and simply disable the password?
                                Maybe if i could remember where it is,remind me where the offsets are .I did use the bios at post #10 ,cleaned the ME and copied the DMI from the original BIOS backup.Not the easiest way to do it,but there`s more than one way to skin a cat
                                  hello guys.. kindly help with this one.. password working bios
                                  thanks
                                    Originally posted by hb83 View Post
                                    hello guys.. Kindly help with this one.. Password working bios
                                    thanks
                                    try..
                                    Last edited by SMDFlea; 04-05-2023, 08:43 AM. Reason: Attachments cleanup,server space low.
                                      try..
                                      thank you very much.. done
                                        Hi guys, I hope I can ask your help in this thread.
                                        I have a V110-15ISK (Type 80TL) laptop with a password protected BIOS and a dead HDD. I tried to replace said HDD with a modern SSD, but it is not recognised by the system. It probably needs some settings changed in the BIOS, but I can't get in.
                                        I tried flashing some of the bios files on offer on this site using WinFlash64.exe which I got from Lenovo's site, but it errors out on me with error 233 (ERROR 233 - Only secured capsule is allowed on a SecureFlash system!).
                                        Do I need another application to flash the file?
                                        Thanks for your help!
