DELL Vorstro 3550 Battery not detected
    Dear all,
    I have recently purchased a DELL 3550 which works fine, but didn't detect the battery or charge it.
    Then I ordered a new one but still the battery isn't detected..what can I check?
    The strange thing is that the unit does run with the battery and without charger, but the battery isn't detected, also in HWInfo.
    Maybe SMBus Problem? How to check it?
    Regards,
    Constantin
    Re: DELL Vorstro 3550 Battery not detected
    when you connect the AC adapter, does the battery charging Led start any activity on the laptop's body?
      no, nothing.
      AC adapter's wattage is correctly detected in DELLs test programm, so adapter and detection of adapter seems fine. I tested with 3 different PSUs: 65W, 90W and 180W.
        bump
          First make sure there's no physical damage near battery connector.
          Measure voltage on SMBUS data and clock lines on the battery connector with and without battery connected.
          And measure diode mode on the same lines with all power disconnected.
            Can you tell me which pins?
            I can upload a picture with the voltages this evening
              Pull out the schematics, find battery connector and you'll see which pins are concerned.
                Okay, I hope the schematic is right...see picture for designation
                w/o battery
                1 2,76
                2 =1
                3 3,36 SMBCLK
                4 3,36 SMBDAT
                5 3,33 BAT_PRES
                6 ground
                7 0
                8 ground
                9 ground
                w battery
                1 9,57
                2 9,58
                3 3,32 SMBCLK
                4 3,3 SMBDAT
                5 0 BAT_PRES
                6 ground
                7 0
                8 ground
                9 ground
                So I think SMBus communictation is working?
                  This might not be the case with you, but I had something similar on an E6540 I just fixed.
                  It worked fine on battery and on power and both together, but wouldn't charge the battery.
                  I found the CD3301 (power management I believe, PU800 or PU801 I think) burned on two pins. Replaced it with a new one, almost losing two traces near the damage in the process. Tentatively added some wire to assist those and much to my surprise, it works like a charm!
                  If you're willing to open it, it's worth eye-balling everything.
                    was the battery detected in HWinfo?
                      I can't remember I'm afraid. Too much time between discovering it and fixing.
                        Looked at all the ICs today and all seem fine
                          It's probably I/O problem.If charger IC is ok then check I/O both scl and sda signals at charger IC communicates with I/O
                            How to check that? What can I do to fix it?
                              Friend without a scheme no one will be able to help you because you do not upload the scheme of the motherboard in order to help you
                              And what teknikbursa refers to is that you check the charger IC the communication inputs and outputs between the charger and the KBC
                              SCL clock signals and SDA data check them with the oscilloscope
                              https://translate.google.com/
