ASUS X555UJ REV 2.0 onboard ram disable help me pls
    I want to asus x555uj rev 2.0 onboard ram disable ..can you help me please
    Last edited by SMDFlea; 07-29-2020, 05:44 AM. Reason: Bios removed.This is not the bios requests section.
    Re: ASUS X555UJ REV 2.0 onboard ram disable help me pls
    it is done not by bios
      It is necessary to disable it on the motherboard. But I do not know how
        I researched a lot but I couldn't find any information according to this model
          y you disable the ram.
            try to look at these thread hope this helps...
            https://www.badcaps.net/forum/showthread.php?t=61655
            Never stop LEARNING because life never stops TEACHING!
              I have reviewed here before, but there are no models compatible with my motherboard. thank you
                Change these tree resistor marked by color
                  thank you test ok ...
                    That work for you?
                      I'm interested. I've shifted those resistors how explained in the pic. But i must desolder the ram modules too? Now, doesn't work.
                      Thank you.
                        thank you ... test ok
                          thank you bro test ok
                            is this correct? i tried this i switched the 3 resistors in that position and it dioesn't work.
                            i shifted from line to arrow.
                            and do i still need to remove the onboard ram?
