Component Identification? What are these?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8694
    I pulled these from somewhere a long time ago and never took a look at what they were. It's too bad that I didn't study the board they came out of, but the board's long gone... anyway, now I wonder if anyone knows what these are...
    When I put an ohmmeter across them they're open both ways. I suspect they're kind of broken but maybe they're nonlinear...
  • trebo
    • 514
    • Wales, UK
    Re: Component Identification? What are these?
    could be zenner diodes,at a guess
    • Blargh523
      • Dec 2012
      • 46
      That would be my guess as well. I'm just not used to seeing color-bands on through-hole ones.
      And good luck figuring out value, AFAIK, manufacturer's didn't really have a standard -- the colors don't translate directly to a voltage value, but to a part number on a look-up sheet -- which is why in most cases color-coded diodes have been replaced with ones with part numbers on them.
      • Phaihn
        • Jan 2009
        • 842
        you mean see through or through hole?
        My Computer.
        AMD APU A4-3300 2.5ghz 1mb cache
        Motherboard GigaByte GA-A75M-S2V
        Kingston HyperX Blue DDR3 8GB (2x4GB)
        SB Audigy 2 ZS [B800] Sound Card
        500GB WD Caviar® Blue™
        1 Terabyte WD Caviar® Black™
        2 Terabyte WD Caviar® Black™
        • Blargh523
          • Dec 2012
          • 46
          Through-hole as opposed to surface-mount (SMT).
          • Phaihn
            • Jan 2009
            • 842
            ok
            My Computer.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8694
              They really do not look like diodes through the glass, but then again who knows... usually there's a visible whisker or orange like the one Blargh posted.
              The fact that they're open both ways is bothersome, unless all four of them were fried at the same time... Very weird. A zener diode works like a regular diode when forward biased.
              The internal construction of these things look like resistors more than semiconductors which bothers me... but then again they may be fried...
              • Evil Lurker
                Warranty Voider
                • Feb 2011
                • 454
                I have seen those before on CRT monitors/tvs on the small driver board that physically connects to the tube pins. Also I have seen similar looking devices on the mains input on some circuit boards. I have no clue what they are either... the only hint is the board is marked "SGXXX" wherein the x's are like any other component numbers.
                • Longbow
                  • Jun 2011
                  • 623
                  I believe these may be transient voltage suppressors, known as TVS diodes. These parts will test open until the rated voltage is exceeded. They come in either mono-directional or bi-directional types. The new ones I have are all in the standard black diode package however.
                  Is it plugged in?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    SG is spark gap.
                    http://img.diytrade.com/cdimg/605332..._Spark_Gap.jpg
                    http://en.wikipedia.org/wiki/Spark_gap
                    --- begin sig file ---
                    --- end sig file ---
                      Definitely minature spark gaps.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Yeah, the definitely are.
                        I have some too. They work like neon lamps, they glow orange at about 80v. They look like the OP's too.
                        Muh-soggy-knee
                        • szreder6
                          HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                          by szreder6
                          Hello guys,
                          I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                          What I did:
                          - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                          As far as I know the laptop was in another service center...
                          11-22-2024, 05:17 PM
                        • Shulgin
                          Acer predator XB241YU Component identification
                          by Shulgin
                          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                          I...
                          05-11-2024, 11:06 AM
                        • thebomb602
                          ASUS GA402R IC identification
                          by thebomb602
                          Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
                          also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
                          EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
                          11-21-2023, 02:30 PM
                        • Tend0
                          hp elitebook 840 G4 no 5v IC identification
                          by Tend0
                          Hello everythone
                          i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
                          i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
                          05-31-2025, 09:13 PM
                        • Tomylee
                          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                          by Tomylee
                          Hi everyone,
                          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                          I'm looking for help with the following:
                          The exact identification or part number of the T5 component
                          05-28-2025, 12:42 PM
