Where to buy replacement "rubber bands?"
  • Freezer
    • Jun 2010
    • 124
    Quick question I'm hoping someone will know the answer to. I have a CD player I need to repair. It has a motorized door, but the door no longer opens or closes on its own. The problem is the "rubber band" that goes from the motor to the pulley on another shaft has stretched out over time. Where can you buy replacement parts like this? I've searched Digikey, Mouser, and Jameco - I can't find this type of replacement part anywhere. Part of the problem is I don't know what the technical term would be. I've tried searching for "band" and "belt" neither of which turned up anything.
    Any ideas? Thanks in advance!
    Re: Where to buy replacement "rubber bands?"
    http://electronics.mcmelectronics.co...square%20belts
    http://electronics.mcmelectronics.co...st&w=Belt&rk=1
    • popeye
      • May 2011
      • 155
      You can buy rubber bands at the stationary store
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Rubber bands and actual proper belts are slightly different, though. Rubber bands are a lot more stretchy but they don't really last as long as proper belts do. A year or two is about the most a regular rubber band would last. If you get oil on it or some other contaminants (not sure which ones exactly degrade rubber bands), they can break down rather quickly.
        • Evil Lurker
          Warranty Voider
          • Feb 2011
          • 454
          Yer standard run of the mill black o-ring would probably work in a pinch.
            Lift Master garage door opener with WiFi capability application through your phone
            by sam_sam_sam
            I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
            This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
            01-21-2023, 08:31 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
            Linear Garage Door Opener Control board took a crap install a new control board back normal
            by sam_sam_sam
            I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
            02-08-2025, 06:52 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
