ReCap on a Monitor Audio RSW-12 Sub
    Got this sub basically for free from a guy a bought some surround sound speakers off. It's a proper beast of a sub and sounds amazing.
    Its basically got a loud hum when powered on, a little hum in standby but mainly when powered on.
    Cracked it open and all Jun Fu caps and from what I've gathered from here is they last just about as long as the warranty does. Given sub is about 6 years old I suspect its the caps. Normally I would just cheap out and just replace caps that need replacing but I think this is worth a full recap and to be fair there aren't that many electrolytics in it.
    Don't want to change the main caps if I don't have to as they are expensive? if not will replace too. Anyhow these are the caps
    Jun Fu - 100uf 100v (HK105 0501)
    3 x Jun Fu - 220uf 25v (RB 0411)
    7 x Jun Fu - 100uf 16v (RB 0502)
    4 x Jun Fu - 22uf 25v (LL)
    Jun Fu - 2.2uf 50v (LL)
    Main Caps
    2 x Jun Fu - 4700uf 80v (LP 0501)
    Questions, will Panasonic FCs be suitable to replace these or do I need audio grade stuff? Or anything better.
    If I was to replace main caps what caps should I use, are the main caps just regular caps or are filter caps a different type?
    Re: ReCap on a Monitor Audio RSW-12 Sub
    replace everything under 80v with panasonic FR
    the others will need to be worked out.
    you should probably post the diameter and height of them and if they use 10mm spaced snap-in terminals
      btw, scrape all that glue off the track-side,
      and make a list of the bastard surface-mount caps
        Oh no the surface mounts too!
        I end up just pulling pads
        Are FRs better than FCs?
        I'll look at the surface mount ones in morning.
          FC are being phased out, FR are like a longlife version of FM - they are also cheaper
            Jun Fu - 100uf 100v (HK105 0501) 10mm x 20mm
            3 x Jun Fu - 220uf 25v (RB 0411) 8mm x 12mm
            7 x Jun Fu - 100uf 16v (RB 0502) 5mm x 12mm
            Jun Fu - 100uf x 25v (RB 0503) 6mm x 12mm
            4 x Jun Fu - 22uf 25v (LL) 5mm x 12mm
            Jun Fu - 2.2uf 50v (LL) 5mm x 12mm
            Main Caps
            2 x Jun Fu - 4700uf 80v (LP 0501) 30mm x 36mm
            Surface Mount
            9 x 4k 22 16v
            2 x 4& 100 16v
            2 x 1 50s G84
            I'm not gonna mess with the surface mount caps, that a bit past my technical ability at the moment.
            Also has 4 x 470nj100 yellow rectangle caps? Seems they are correction caps. Are these worth changing too?
              Not impressed with how thermal paste is making contact with heatsink. Not even spread, cant imagine it would be transferring heat away efficiently.
              Some shots of the board with the surface mount caps on. Out of my league changing those. But will do the others first and see how it goes.
                4 x 470nj100 / EPCOS B32529C1474J189 Film Capacitor http://uk.farnell.com/epcos/b32529c1...rad/dp/2315556 (not sure on this)
                Mostly FR with a couple of FCs, how does that look?
                  looks o.k. dont bother with the film caps
                    Would the surface mount caps be as bad condition wise as the junfu stuff?
                    Any tips on how to do these, I might just order some. Only just do the JunFu caps first and if the fixes it will leave the others. If not will change the SMD caps too or attempt to anyway.
                    Anything else I should look at?
                      They don't have any 22uf 25v FC series in stock (Nor others FR etc) Am I ok going with 22uf 35v FC series on these?
                        35v is fine - try to use FR rather than FC
                          Changed over all caps and just about to put back together.
                          Many of the caps reading low and all had very high ESR compared to the new Panasonic ones.
                          I'm using http://www.ebay.co.uk/itm/181861030068 , that you linked to in another thread. Not sure how accurate it is as first time using it but new Panasonics are reading
                          Pana FR 220uf 25v = 207uf 0.14 ohm ESR
                          JunFu 220uf 220v = 167uf 3.3 ohm ESR
                          JunFu 220uf 220v =182uf 4.8 ohm esr
                          JunFu 220uf 220v =97uf 0.14k ohm esr
                          Quite a few others are reading low too.
                          Is ESR something that can deteriorate as well or is that their standard spec?
                          That's like 30x the ESR
                            All sorted, working like a champ.
                            No hum in standby or on. shame they used junk caps on what was a £700 sub.
                              Am about to do this job on my own amp but rather than Panasonic caps I am thinking of using Rubycon but am unsure which would be the best type (series) to use.
                              Any advice gratefully received
                                Just had a mate with the same loud hum problem with his RSW12. I had some cheap caps in a packet and have now just replaced the 3 - 220uF 25V caps and already it is much better. I will prob replace the others in the list above as well. 20 mins work and 50p of cheap caps (not ideal but was just a test) and it looks like we have a solution!
                                Thanks OP and others for your valuable help.
                                  I also have this humming sub. I just received new caps today - all ordered from mikay786's shopping list. Thank you very much for taking the time to write that. :-)
                                  Since I'm no expert I will perform the procedure on sunday to make sure I have plenty of time, so there is no stress.
                                  One thing I couldn't quite figure out is from your posts; did you end up leaving the original 4700 uF 80 V caps in or did you replace them too?
                                    Forgot to say: Also thanks to stj for the input. :-)
                                      The large capacitors should be replaced too, they do most of the hard work. If there is room, there will be no harm in going for a higher capacity value, it will give more reserve headroom for those long bass notes or explosions.
                                      A working TV? How boring!
                                        Out of interest, how hot was your soldering iron that you used to get the old capacitors off of the board?
