Vizio 55" M550SL No volume up or down
  • high-tech
    • Sep 2010
    • 197
    Hello, and how is everybody doing? This Vizio's volume controls don't work on the tv and the remote... I don't yet have this tv, its waiting to be picked up... I'm wondering if this could be firmware or stuck, bad button on the televisions button panel...
  • kgavionics
    • Apr 2017
    • 152
    Re: Vizio 55" M550SL No volume up or down
    We need more information. Does the volume bar shows when you change the volume?
      +1
      Also may be there is no sound so they say the Volume doe not work.
      • high-tech
        • Sep 2010
        • 197
        I just called to see if I could get this tv and apparently I was to late, thanks so much for being here, this is a great place to gain knowledge. I'm addicted to this stuff, I can't get enough... If there is ever anything that I can do to help, I'm on it. I'm a journeymen Electrician certified by the state of Arizona and very well versed in NEC AND NFPA 70 codes I have that knowledge to offer anytime!!!
        It's second nature to me so don't hesitate ��
          • 12093
          • U.S.
          Well alright then, THAT'S the kind of enthusiasm I like to see, hope you get the next one.
          • karthur
            Vizio D65x-G4 Volume changes on its own
            by karthur
            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
            06-05-2025, 08:13 AM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • crackedprint
            Sony HCD-HX80R Amplifier Volume Control Problem
            by crackedprint
            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
            I have tried a Cold Reset as per the service manual.
            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
            I have looked all the way through the service manual and tried many online...
            01-21-2025, 12:18 PM
          • BigOof
            Marantz SR5007 popping on volume change and mute in Direct Mode
            by BigOof
            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
            12-12-2024, 06:15 AM
