I recently bought a secondhand HP L1955 which worked fine for exactly one month (doesn't really matter how long it worked since I have it because it is a secondhand, but anyways).
Then it went black and seemed not to detect the signal, after unplugging it sometimes worked for a while, sometimes not. I pulled the board and found one bulged capacitor (10v, 1000mf, at C709). I replaced it (16v, 1000mf, same heat rating 105 deg C) and it worked fine for 10 days.
Then, after about one hour, it went black. Turning it off (with the "soft" switch, not the main PSU switch) made the screen come back for a couple of minutes, then went black, switching off/on and so fort until the screen only stays on for a couple of seconds.
I opened it up again, but visual inspection didn't show anything wrong. Since, I am searching the internet for a possible diagnose, and I can tell you I, I have read almost every single post the common C5707 failure, this monitor and similar Benq inverter boards.
My question is: is this new problem likely to be caused by the C5707's? I know to assure i should test them, but right now I am using this monitor and it has been powered on (that is: without the cover, so it's getting less hot), for about an hour. So is it likely to be a 5707 faliure with heat or something similar? Or does it, from your experience, sound more like some sort of a capacitor failure?
Thanks for any thoughts, this forum has already helped me (a novice when it comes to electronics) to understand a lot about this monitor, inverter and its major problems, but right now i'm not able to make a judgement on what is likely to cause my problems.
EDIT: let me tell you i planned on checking with a strong light if the backlight's are turned off, but since I planned on doing so, the monitor didn't go black on me... When it did go black, the power light was on (green)
