15-ay011TX BDL50 LA-D704/D703 rev 1.0
Hp bdl50 la-d704p rev:1.0
Re: bdl50 la-d704p rev:4.0 bios
Re: bdl50 la-d704p rev:4.0 biosAttached FilesLast edited by SMDFlea; 05-26-2020, 03:41 AM.
Re: Hp bdl50 la-d704p rev:1.0
https://www.badcaps.net/forum/showthread.php?t=84808 Post #1 has 4 different bios extracted from the HP bios update. Open your bios with a hex editor and search for the word BID ,that will give you the bios you need to use.
https://www.badcaps.net/forum/showthread.php?t=67592
Re: How to extract EC bios from Main Bios
Laptop make and model number....... ?????????
Originally posted by erbuzzicker View PostHP 15-ay018nl
Motherboard BL50 LA-D704P Rev. 1.0
Originally posted by erbuzzicker View PostHere is it. Can you please explain me how to get it from BIOS? I already have HEX editor.
Originally posted by erbuzzicker View PostPlease, try to be more clear.
There are several parts of the file with the writing "ENE" (in this case): which of these to consider?
Once I found the correct one, what should I do to get only the part for the EC (I suppose it should be of 128 KB)?
use the HxD program..entert the bios in the program, type search..ENE ... KEY f3 UNTIL YOU REACH THE VALUE 214000 and then check 128kb or (20000) new copy-pasteAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by erbuzzicker View Postplease, try to be more clear.
There are several parts of the file with the writing "ene" (in this case): Which of these to consider?
Once i found the correct one, what should i do to get only the part for the ec (i suppose it should be of 128 kb)?
Become a Badcaps supporter
Thanks to all supporters.
