this card is the same as that of the other discussion E5440 VAW30 LA-9832P, connecting power turns on the power led and fan at max for 3 sec then all off, as if you didn't see the ram, then if you turn it on again with the power button it doesn't turn on, I tried to disconnect the power supply and jumper pins 5 and 6 of U1 and U2 while I re-connected the power supply, and it turned on normally, then after turning it off when it was turned back on it didn't turn back on like at the beginning
dell e5440 turns on 3 seconds with fan at max
Re: dell e5440 turns on 3 seconds with fan at max
I solved the problem, making a check of the present voltages, measuring the + 1.35V-MEN-P this was not present, measuring on PQ100 the pins 5-6-7-8 there was no voltage, on PL101 the + PWR- SRC was present on point 1 but not on point 2 of the coil, measured in ohms it was ok but it did not make contact with the pad, the welds on the coil were re-made 1.35v_B + is adorned on pins 5-6-7-8 of PQ100 and so even the + 1.35V-MEN-P is back and the notebook has started working again.
regardsLast edited by poweron; 06-18-2019, 02:04 AM.
Originally posted by mnciks11 View PostSend the schematic I want to see you solved this
Bios. https://www.badcaps.net/forum/showthread.php?t=70030
Originally posted by SMDFlea View Post
