Need Bios HP 470-G4
    Need Bios HP 470-G4
    iam looking for a bios bin file for HP 470-G4
    Thnx for support ....
    Re: Need Bios HP 470-G4
    Post here old bios i build new
      should i read the old bios with programmer and post it here ?
        plz test
          Yes right i build new if bios problem i sure your problem solve.
            Hello , thanks for your support i will test it and inform u about
            for first thank you & hodafez
              i will read the old bios and upload it, thnx for first ...
                Hello please can u repair this bios file, it is the org. bios wich is faulty ive read from book.
                HP 450 G4 bios is working but not correctly with this board
                  [QUOTE=Richi_el;882317]Hello please can u repair this bios file, it is the org. bios wich is faulty ive read from book.
                    Try this.
                      Try this.
                      Hello i ve tested the file but it doesnt work no reaction on book
                      the book started with the bios File
                      Type: rar 450 g4 DA0X83MB6H0 REV H.rar
                      from mahmoodjavan
                      but the problem is that some features in this bios file are missing for the 470 g4
                      please can u check the file again ?
                        from mahmoodjavan
                        Where is original bios bad file post here i try to fix.
                          This one is wich ive read (bad file)
                            Try this both file.
                              Try this both file.
                              Thank you worked fine
                                Are those two file personal to his system or would I be able to flash them also?
