This is Why You NEVER Ignore Bad Capacitors!
This is a sticky topic.
  • S_S
    • Sep 2017
    • 16
    Re: This is Why You NEVER Ignore Bad Capacitors!
    Originally posted by stj
    it's not a design fault - supercaps do that.
    you can just leave it out on a 1.0 - 1.5 series board.
    on a 1.6 board you need "something" or it wont start, so i fit a low impedence 220uf cap.
    I read that the capacitor fails prematurely because it's undersized or the circuit isn't built correctly.
    (original XBox)
    If it's just a case of these capacitors having a lifespan limit then Microsoft should have warned buyers in the manual in a prominent location or, better yet, should have figured out another way to keep time — like a battery.
      • 30965
      supercaps have a life rated in charge/discharge cycles,
      m$ should have fucking known from the datasheets that they wouldnt last a year!!
      more importantly, they should have not bothered with an RTC,
      it's a games rig - it does not need to know the date or time.
      hell, only the m$ dashboard that nobody even uses anymore even uses that data!!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8689
        how many charge/discharge cycles should a EDLC sustain? That doesn't sound right, if it only can take 1000 cycles or so, that's no better than a rechargeable battery?
        They probably have the RTC for DRM/key exchange or something for encryption. Maybe use it to seed the network prior to network time becoming available... Just speculating...
        • Stefan Payne
          • 1267
          If it's the first XBox with the 733MHz Intel CPU and the nForce shitset, than probably because it's a PC in console format.
          And not that much custom stuff compared to modern consoles...
          Modern consoles are totally custom, specified by the console seller....
          • gryffinwings
            • Sep 2018
            • 24
            These images are making me really consider not putting off replacing caps that are going bad in my computer, here are some Nichicon 3300uF 6.3v 105 H0139 HM series capacitors on my Asus A7V266-E motherboard that are in need of replacement. Definitely looking at putting in some polymer caps in there.
            • Behemot
              • 4845
              • CZ
              #66
              Gonna have to try polymers, it may or may not work. But 39th week of 2001 is among the years of bad HN, HM caps so nothing surprising there.
              • PeteS in CA
                • Aug 2005
                • 3578
                • USA, Unsure of Planet
                #67
                Not contradicting, but a 17 year life isn't exactly awful.
                PeteS in CA
                • Behemot
                  • 4845
                  • CZ
                  #68
                  Yep, likely just a light use most of the time.
                  • Stefan Payne
                    • 1267
                    1) the Pics don't work (no more?)
                    2) In that case you could eventually try ramming in 12,5mm 16V/3300uF Panasonic FM. Those have similar or the same value than the Nichicon. Problem: they are way bigger. And the only caps, to my knowledge, that are widely available and can be used as replacement of Nippon Chemicon KZG and similar...
                    Though it needs some creativity as the caps are 25% bigger...
                    • Behemot
                      • 4845
                      • CZ
                      #70
                      Suncon still produces WG so 3300/6.3 are still easily available, plus I got some stock of Rubies MFZ 2700/6.3.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        I'm not sure where you're getting them, but they're nowhere to be found with my regular haunts.
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Behemot
                          • 4845
                          • CZ
                          #72
                          Wanna some? Should have some of them moneiz around the end of the year so I could actually finally order some (they still want payment in advance) Will likely start with 1800/6.3 D8 though since I have those D10 MFZ which are more than fine for any board.
                          • Escribblings
                            • Dec 2019
                            • 7
                            • United Kingdom
                            #73
                            This is what happens when you release the magic smoke :'(
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Ironically, minus cap problems, the PC-based version 1x XBoxes seem to be much more reliable than an XBox 360, especially the early XBox 360s!
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                                • 30965
                                the 360 biggest problem is again the clowns at m$ hardware center.
                                they put an undersized heatsink on the gpu and then put a dvd drive above it.
                                forget all the crap you hear about washers, screw-kits, reflow etc.
                                all you need to do is remove the dvd drive and put a spare cpu cooler on the gpu and they run fine!!
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Well, like with today's video cards with turning up the fan, if that was done when it was brand new, then the solder probably wouldn't crack or move.
                                  Arc A770 16 GB
                                  • Heihachi_73
                                    • Jun 2012
                                    • 713
                                    An old news article, but still relevant...
                                    https://wongm.com/2015/01/melbourne-...iemens-trains/
                                    (Note, the blog as a link to articles from The Age, which is a paywalled news site, if you absolutely need to click on them, open the links in private/incognito mode to get around it)
                                    • andrewsawesomr
                                      • Jun 2022
                                      • 100
                                      • United States of America
                                      #78
                                      They're available at LCSC (https://www.lcsc.com/mobile/product-...G_C242095.html)
                                        Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                        by momaka
                                        I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                        For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                        https://www.badcaps.net/filedata/fetch?id=3591771
                                        https://www.badcaps.net/filedata/fetch?id=3591772
                                        It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                        https://www.badcaps.net/filedata/fetch?id=359177...
                                        03-12-2025, 03:42 PM
                                      • eryjus
                                        Heathkit IO-4205 Power Supply Caps
                                        by eryjus
                                        First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                        I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                        I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                        05-10-2023, 11:21 AM
                                      • Paxman_Swede
                                        Identifying caps on an old Zoom 9000
                                        by Paxman_Swede
                                        Hello!
                                        I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                        The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                        I have studied the board and...
                                        01-14-2025, 09:51 AM
                                      • captain150
                                        Help with switching power supply caps
                                        by captain150
                                        I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                        I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                        03-16-2025, 07:34 PM
                                      • Foetuss
                                        Gigabyte GA-6OXT :: caps question
                                        by Foetuss
                                        Good evening
                                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                        But I was also suprised about the bigger boys, which are 330µF 25V.
                                        Could it be they used 25V caps because they were cheaper / available at that time?...
                                        02-11-2025, 12:22 PM
