Dead Supermicro C2SBA
  • Logistics
    • Apr 2007
    • 721
    I bought this board on craigslist for $35 and cannot for the life of me get it to post.
    All I can imagine is someone bricked the BIOS. Any ideas? I'm using good RAM, and my previous quad-core which I also know works.
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    Re: Dead Supermicro C2SBA
    Checked CPU list for the board? It may not be supported by the motherboard.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • RJARRRPCGP
      • Jul 2004
      • 6301
      If LGA 775, good chance of a bad socket pin.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Logistics
        • Apr 2007
        • 721
        I will look into that. I have another board which acts strangely, and I believe it's due to a damaged pin it has. Ill check the Supermicro board out. Maybe that's why he said, "I installed the CPU for you because its easier to transport. (I had also purchased a Q9450 from him, but swapped it into my system and put a Q8400? back in this Supermicro board.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Do you mean it does power up, but doesn't POST ?
          If doesn't POST, have you tried JBT1 = CMOS Clear ?
          And does its CMOS battery have ~3V ?
          Strong possibility if my experience here ...
          https://www.badcaps.net/forum/showthread.php?t=36190
          ... is anything to go by
          IMO there is a reason why SuperMicro make you accept a disclaimer to download a BIOS update
          And FLASH.BAT for C2SBA looks even more amateurish than AMI.BAT that caused my grief
          2sbaC198.ROM doesn't look like a ROM image (not multiple of 16) so I reckon you'll have to hope for the best from SuperMicro's BIOS recovery procedure
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            If the BIOS is bad, contact SM, for a small fee ($18 + shipping in my experience) they'll ship you a factory flashed replacement chip if it's socketed (being SM it almost certainly is).
            I then suggest hotflashing back the bad chip so you potentially get a 2nd good chip as a spare.
            sigpic
            (Insert witty quote here)
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Not necessarily - looks like SPI BIOS chip, SMT, left of south bridge in this pic (with red dot)
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • disorder
                ps5 edm-033 dead after hdmi/usb ports destroyed
                by disorder
                hello guys,
                i need help to repair a edm-033 ps2
                history : as always hdmi port and usb ports destroyed after unplugged
                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                so i changed it
                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                i don't see any projection of liquid metal on pcb.
                01-14-2025, 12:48 PM
              • Beton
                Finding a dead short component
                by Beton
                Hi guys!
                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                I have a bench PSU and if I try to inject voltage the voltage...
                12-10-2021, 01:05 PM
              • zunasthegreat
                Chieftec GPS-450-AA with dead 20N60C3
                by zunasthegreat
                Hello everyone hope all doing well!
                I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                09-01-2024, 07:12 PM
              • FiguringITout
                MSI Raider GE75 - Not posting, probable dead CPU
                by FiguringITout
                Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                07-25-2024, 07:27 AM
