Samsung LE52M86BD 52" faulty BN44-00150B PSU
  • Escribblings
    • Dec 2019
    • 7
    • United Kingdom
    Hi.
    Have the dreaded clicking TV on power on, but it will EVENTUALLY turn on and otherwise works ok.
    I've already taken it all apart once, and the 4 1000uf 25v caps were obviously blown.
    We've already replaced these with 1000uf, 25v, 105°C - unknown brand, it's what my Brother-In-Law had in his kit.
    Having looked online it seems that the repair kits for this revision contain 9 caps, the 4x 25v that I've already replaced, plus 5x 10v that "looked" ok.
    I'm planning on getting decent Japanese caps and replacing the lot, but I do have 1 question...
    Should I up the v rating?
    Should I put 16v or 25v in place of the 10v? And 35v or 50v in place of the 25v?
    I was planning on 16v and 35v - but then I stumbled across the minefield that is ESR, and don't know if the increased voltage capacity would cause an ESR issue in this instance. I'm assuming that as the Samwha WB series are supposed to be low ESR, that shouldn't be an issue.
    I believe this is the correct Datasheet: https://cdn.badcaps-static.com/pdfs/...e01af2af63.pdf
    I've also found this parts list: https://cdn.badcaps-static.com/pdfs/...6a12f5e38f.pdf
    Code:
    Vendor | Product | IP/SMPS   | Location           | CAP  | CAP  | Part Spec       | SIZE | SVC Part
        |     | Part CODE  |                | Vendor | Series |            |    | CODE
    HANSOL | S-IP 	 | BN44-00150B | CM802,CM803,CM807,CM808    | SAMHWA | NXB  | 1000uF 25V 105°C 10*20 | 10*20 | BN81-02020A
    HANSOL | S-IP 	 | BN44-00150B | CS804,CS805,CS806,CM812,CM813 | SAMHWA | NXB  | 1000uF 10V 105°C 10*16 | 10*16 | BN81-02017A
    I'm presuming the NXB is a newer line? They're not solvent-proof like the WB are... Anyway, I found their sheet too: https://cdn.badcaps-static.com/pdfs/...82f02d80b8.pdf
    I'm not used to datasheets, but if I'm reading this correctly, then the specs of the caps are as follows
    Code:
    WB  10 v  10.0 Ø x 16.0 mm  0.038 Ω
    NXB  10 v  10.0 Ø x 16.0 mm  0.038 Ω
    WB  16 v  10.0 Ø x 20.0 mm  0.027 Ω
    NXB  16 v  10.0 Ø x 16.0 mm  0.038 Ω
    WB  25 v  12.5 Ø x 20.0 mm  0.025 Ω
    NXB  25 v  10.0 Ø x 20.0 mm  0.025 Ω
    NXB  25 v  10.0 Ø x 25.0 mm  0.022 Ω
    WB  35 v  12.5 Ø x 25.0 mm  0.018 Ω
    NXB  35 v  12.5 Ø x 20.0 mm  0.021 Ω
    NXB  35 v  12.5 Ø x 25.0 mm  0.020 Ω
    Looking at those specs - if I were to stick with Samwha WB- then the 16v in place of the 10v and the 35v in place of the 25v should pose no issue physically. The lead spacing on all of them is 5mm too (which if I go up to 50v changes!)
    The NXB 16v ESR matches the 10v, the WB 16v is lower. The NXB 35v ESR is higher than the WB, but still lower than the 25v.
    There is probably enough space to replace them all with the larger physical size.
    I'm not sure about the other caps in that area - 3 look to be more WB series, but 470uf 50v. As for the 1 with the black top - it's not black, it is actually silver - it's just the reaction to the flash combine with its angle. It's probably the same as the others, but I can't tell without taking it out again.
    I have 1 further query...
    I have found this: https://www.justanswer.com/tv-repair...-clicking.html
    Originally posted by TV Technician: ziane Hassan
    Hi
    these are the repair tips for your tv
    -check capacitors CS804, CS805, CS806, CM812, CM813 (all 1000uf/16v)
    -Tip for appliances using the BN94-01206D signal PCB. (Relay clicks slightly faster with a NVM corruption problem. R1131 and R1132 (both 68R) have visible signs of overheating. 13V is measured at one side of these parallel-connected resistors (while relay is on) and 1.2V at the other side. 210R is measured across C1102 (1uf/16V), in line with the 2 resistors. if C1102 is removed then only 37R can be measured . Replace C1102 (with 25V type), R1131 and R1132 (both 68R) at the underside of the signal board, next to connector Cn1101.
    -(Electrolytic capacitors in PSU have been replaced). NVM memory IC1803 (AT24C256) has corrupled software. then replace NVM memory IC1803 (AT24C256), then proceed as follows: switch of appliance via mains switch, then solder two long wires at PIN 5 and 6 of IC and short them at the other end, then start TV via main switch, wait maximum 1-2 seconds ( a click can be heard, backlight doesn't switch on), the remove the short circuit at the two wires. NOTE: it is important not to exceed the time limit(1-2 seconds), otherwise the procedure will have to be repeated, then access service mode (INFO, MENU, mute) . select 'tuner' line and set it to 'AUTO' . then select RESET line. the set should reset itself and upon start-up, it should start automatic search.
    I note in this reply, and in some of the repair kits offered on the bay of e, the IC IC1803 (AT24C256) is suggested to be replaced, and that this is an EEPROM.
    The TV does work normally once it eventually starts, so I don't think this needs replacing - but if it did, does it need to be programmed or pre-programmed? Or is that all done by the TV itself during setup?
    TL: DR ?
    1. Can I use higher voltage/lower ESR caps?
    2. Do I need to change IC1803?
      1. Does it need pre-programming
  • Escribblings
    • Dec 2019
    • 7
    • United Kingdom
    Re: Samsung LE52M86BD 52" faulty BN44-00150B PSU
    If the answer to TL: DR Q1 is yes, then I'm looking at Panasonic FM series 16v and 35v
    https://cdn.badcaps-static.com/pdfs/...404c12c252.pdf
    Code:
    FM  10 v  10.0 Ø x 16.0 mm  0.026 Ω
    FM  16 v  10.0 Ø x 20.0 mm  0.019 Ω
    FM  25 v  10.0 Ø x 20.0 mm  0.018 Ω
    FM  35 v  10.0 Ø x 25.0 mm  0.015 Ω
    • R_J
      • Jun 2012
      • 9535
      If the tv turns on and works, the eeprom is ok. if the eeprom was bad or the data corrupt the tv would usually not turn on at all.
      I would use 16v to replace the 10v as long as the diameter will fit. and you could also go with 35v to replace the 25v caps, likely once replaced they will out last the life of the tv.
      • Escribblings
        • Dec 2019
        • 7
        • United Kingdom
        Thank you, the can diameter on the upgrade of 10>16, and 25>35 is the same, and there's plenty of height. So I'll do that.
        I take it the lower ESR won't be an issue?
        • Escribblings
          • Dec 2019
          • 7
          • United Kingdom
          HELP!
          Right, so when I turned up, I was told that the screen had now give black, but there was still audio.
          I proceeded anyway.
          I've replaced all 9 caps with the above Panasonic's.
          Got it all back together and it's still clicking - took 15 minutes to turn on in total.
          BUT - They have at least got the picture back!
          Could it just be a poor joint?
          Or could it be something else?
          • Hitto
            • Apr 2019
            • 95
            • Italy
            Have you replaced the small capacitors? They are as important as the 1000uF ones.
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • b-slayer
              Acer A317-53 need help to disable faulty onboard ram
              by b-slayer
              Hello.
              I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
              - first one is to modify le bios to disable the onboard ram.
              - second one is to disable the onboard ram by desoldering some components on the mainboard.
              so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
              so i found that my motherboard...
              10-12-2024, 03:46 AM
            • brispuss
              Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
              by brispuss
              Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
              Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
              I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
              12-28-2022, 02:58 AM
            • lolich112
              GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
              by lolich112
              I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
              Symptoms:
              Initially experienced a gradient-style black screen from the top.
              Poor performance: ~10 FPS on the lock screen.
              Encountered artifacts followed by black screens.
              After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
              Upon using GPU-Z:
              Memory size shows as 0MB.
              Unknown bus width and bandwidth reported....
              10-27-2023, 06:17 AM
            • Byte_76
              Faulty memory slot on Tekram Slot 1 motherboard
              by Byte_76
              I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
              When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
              Also, the floppy drive does not work regardless of bios settings.
              Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
              I have examined the board under my digital microscope and did not find any broken traces....
              04-12-2025, 06:58 AM
