DELL XPS 13 battery not detected
    hi guys
    xps 13 motherbosrd AAZ80 LA-C881P
    Schematic attached
    255% remaining
    pluged in not charging.
    battery was replaced but still same problem.
    no shorts and diode mode readings on DAT_SMB, BAT_PRS,SYS_PRES are good
    with charged battery the laptop will work until it drains.
    any ideas?
    thanks
    Re: DELL XPS 13 battery not detected
    What are the voltage and diode mode measurements on SMB CLK and SMB DATA?
      with charger and battery connected :
      batt + 6.6V
      CLK_SMB 1.6V
      .DAT_SMB 2.2V
      BAT_PRS 0V
      short to ground when i connect battery on BAT_PRS
      thanks
        Originally posted by claudyu07 View Post
        hi guys
        Schematic attached
        255% remaining
        any ideas?
        thanks
        I suspect battery is dead as it showing 255% remaining.
