Sacon FZ revival experiment
    Re: Sacon FZ revival experiment
    you take the readings as a whole.
    if capacitance and esr look o.k. then v-los you think about,
    but it's more common with high v-loss to also have high capacitance - then you know the cap is fucked.
    best i'v seen was 3300uf caps reading over 9000
      Well, these are probably good contenders:
      Rubycon MFZ 6.3V 2700 uF reading ~6300 uF
      And Sanyo WF 6.3V 1500 uF reading over 4000 uF
        an un-molested GM328A!!!
        you need a rotary encoder and a faster crystal and a better regulator
          Originally posted by eccerr0r View Post
          The v_loss
          video about vloss - it is very inaccurate
            Nice video!
            I like that they guy is showing actual V_loss with higher voltages (26V in his video, if I understood correctly) and over a long period of time, therefore being able to get a more accurate estimate. And also the theory of how he is calculating it! Very good and informative.
            However, in the case of electrolytic capacitors, I think we also have to remember that -used- capacitors will become pre-formed to a certain voltage after being used in a circuit for a very long time - e.g. 6.3V cap used on a circuit that handles only 2.5V will make the cap "accept" up to 2.5V easily, but any higher voltage will experience a much greater V_loss. Thus, for electrolytic capacitors at least, V_loss can be very non-linear depending on the test voltage used. On that note, if these cheap testers show high V_loss on a cap, chances are that it's in pretty bad condition already. I say "chances", because sometime I have seen caps fool the meter to display high V_loss (or a few polymer caps, in particular) without there being anything wrong with these caps. Perhaps someone should make V_loss a separate function on these cheap testers that measure it over a longer period of time and with a higher voltage applied onto the cap, just like in the video - then V_loss could become quite accurate, possibly.
            Eh, maybe another day. Too many projects to thinker with and I use this tester a lot... plus, it still works. So it always goes to the back of the queue. Perhaps if I get a 2nd one of these, I'll try it (and I think I might try to get one... eventually.)
              It's over 9000!
              Ugh want something to read not watch...
                It's over 9000!
                So put on subtitles for the video?
                  Transcript with finger pointing? Or do I still have to wait for the whole thing to be played?
