Hi to all,
I've been scratching my head for several days on this Oled issue with only 3/4 of the screen is flickering and will turn off due to Burned Panel protection. The Service Menu shows an Instart log of an Inverter Error. I've manage to bypass the Protection circuit to further analyze and find the cause of the Inverter error and found that its the VGH_E on the right side of the TCON(CN14) is causing the Inverter Error. Tried to block that VGH_E but the screen flickering was just reduced to only 1/4 side of the screen. All voltage check are normal on the TCON side.
Hope someone can share some ideas to fix this or this is already hopeless panel issue.
Thank you,
Thank you,
