acer aspire E1-410 BIOS dump needed
    Infos:
    EA40--BM MB
    13233-1M
    48.40C10.01M
    thanks...
    Re: acer aspire E1-410 BIOS dump needed
    try this
      backup old bios and try this
      if you need ec, read old and post here
      Im Back... sort of...
        The bios chip is not supported by my SP8-A programmer. It's winbond 25Q64FWSIG, it only support FV model... i tried to select FV then make backup but i'm not sure if it's a good backup. I haven't yet tried to reflash the bios chip. My backup is 8mb. And i only found 1 bios chip on this board.
          I just tried using MXIC 25L6406E as replacement then used the above given files but both ended up on No Display problem...
            any bios programmer could support this chip?
              i have cheap EN25T80 programmer and it works fine once you have drivers working....
              and if even if it dont support that id, jucst click force id, select size and you are good to go
                Thanks... but i'm afraid that it might end up a no display or a dead unit... BTW, the main problem with this unit is that it won't boot anymore on internal hdd and any usb drive. It can detect the main hdd as seen on bios setup. And any changes being made on bios setup and upon restarting it always goes back to default. And even the internal hdd had an OS installed like windows 7 or 8 it always show No Bootable Device Detected....
                  thanks
                    thank you
                      thanks....it works
                        thnks
                          where is ec bios acer aspire E1-410 plz help me
                            thank a lot
                              thank for all
                                DA0R75MB6C1 any one have this bios bin plz
                                  Originally posted by alihomee View Post
                                  try this
                                  this bios lock by password, please give the password. thanks.
                                    its 1.8v chip. u need 1.8v adapter to program this chip else you will end up with no display only. If you dont have a 1.8v adapter then there is a way out to program this type of chip. See attached photo-it will be clear to you.
                                      ea40-bm mb schematic need
                                        Please, Use search button first, Of course after login.
                                        https://www.badcaps.net/forum/showth...ghlight=E1-410
