asus X507MA
    asus X507MA
    notebook turns on with no display anyone can rebuilt bios ...many thanks...........model is..A507M ....mobo code is X507MA REV 2.1
    Re: asus X507MA
    bios extras from the updated Asus site
      Re: asus X507MA
      it works perfectly for me
        Re: asus X507MA
        thanks so much....very very much
          Re: asus X507MA
          thankyou work for me
            Re: asus X507MA
            Thanks It Works...
              Re: asus X507MA
              Not working for me. It got better (battery started charging, all voltages are present, but cpu is just getting warm and no display, it reacts to power button too). Attaching backup dump.
                Re: asus X507MA
                Post a picture of the long white barcode sticker. It will have a model number on it. Like the ones in this thread https://www.badcaps.net/forum/showthread.php?t=96604
                  Re: asus X507MA
                  Let me know if you need any additional information.
                  P.S.
                  Thanks for that link, it's very interesting to understand more things on what's going on here.
                    Re: asus X507MA
                    P.S.
                    for this laptop the bios from post # 2 should work, the bios you posted is longer ... maybe you typed the bios with errors ... try writing the bios chip again ..
                      Re: asus X507MA
                      Tried again today, no luck.
                      I found some intersting posts from other forum (in attached image). First post got the problem solved with some other bios which i can't try, because I can't access the link (not a member of that forum).
                      But symptoms are identical.
                      Also tried to swap RAM, as sometimes similar issues can happen with bad RAM.
                        Re: asus X507MA
                        thanks work for me.
                          Re: asus X507MA
                          try clean me.
                            Re: asus X507MA
                            hi friend.. ur have asus x507ma EC Bin? ic is it8225e-128
                              Re: asus X507MA
                              try..
                                Re: asus X507MA
                                hello sir do you have pinout for it8225e-128 using ch431a mini programmer thank you
                                  can you rebuild this my original file ,led power is appeared but not power on ..thank alot
                                  Serial number ?
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                    Originally posted by hoaca388 View Post
                                    Serial number ?
                                    machine name x507ma-br211t
                                    board x507ma rev 2.1
                                    sn JAN0CV11L001438
                                    THANKS
                                      sn JAN0CV11L001438
                                      THANKS
                                      X507MA
