Some True BCN History - Homecoming of a long lost friend!
    Re: Some True BCN History - Homecoming of a long lost friend!
    TopCat
    Just how many computer do you have because in one of the pictures I saw a lot of them on a shelf
    But very nice work ——> you must enjoy what you are doing <—— keep up the good work
    I appreciate you for putting affordable computer system together for people in this pandemic and the hardships that people are facing “ Thank You ”
    I find your comments about problems that you run into that take a long to figure out [ a waste of time ]
    Very funny I have had the same thoughts a few times myself
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      I really don't know. What was shown on that shelf isn't even the tip of the iceberg. There's gotta be over 100 of them around here....they breed at night, along with monitors & keyboards... Some of the more useless/bad systems I've been dismantling and ebaying or recycling...otherwise this stuff will run you out of your own shop!
      When the panic set in, I sold every laptop I had, and finally started selling desktops when the laptops ran out. I got to the point I had no more decent desktops available/ready that I lent out THIS BUILD to a customer that needed a pretty powerful workstation with multi monitor support.... It worked for several months while the customer gathered the funds for a more modern build, and I got the hobbyist build back when the new one was ready. It kinda made me smile inside a little knowing that something that was built to be a time-wasting toy ended up helping some in need.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        Originally posted by Uranium-235 View Post
        Jeez when I first read this title I thought you were talking about someone coming back to the forum like PCBONEZ. What happened to him??
        I think there was a dispute between him and another member, though I don't remember the details too well and over what.
        Then again, I've seen a lot of good people come and go ever since I joined here.
        Originally posted by Topcat View Post
        I think Mathog ran him off with his far left weirdness.... I hope he's doing ok....IIRC he was up in the years and not very healthy....and it's probably been a good 10 years since he's been on.
        He hangs out over at Vogons.
        Here is a thread where I linked a Vogons post where he posted:
        https://www.badcaps.net/forum/showthread.php?t=86188
          Glad to know the old chap is ok...
          Team : 49813
          Join in!!
          Team Stats
            well there went 5 hours of my life I'll never get back. Installing the OS on SYS-B kept yielding BSoD's....after eliminating all the RAM, I focused on the motherboard and processors....long story short, I finally saw a second bad intel processor in my computer career that spans more than 2 decades! Wonky Prestonia 2GHz CPU. I had a pair of 2.4GHz Prestonias in an old Dell workstation. Issues went away. I managed to narrow it down to which one it was....so I could properly salute it...
            If you got "0x0000000A", then it probably is a failed CPU, FYI, unless it was an unstable CPU overclock.
            Loss of RAM stability, OTOH, is likely to be "PAGE_FAULT_IN_NON_PAGED_AREA" or "BAD_POOL_HEADER" (Possibly 0x0000008E as well)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            16 GB AData XPG Spectrix D41
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              Reread the thread....
              Long since diagnosed and corrected.
              Team : 49813
              Join in!!
              Team Stats
                So this thing is back in the news....this time it's cycling out HDD's that are 10+ years old.
                I normally don't run them past 5, but time got away from me and there were no bells & whistles from the RAID controller... Whoever says WD Greens are junk can go eat some crow. 11yrs of flawless service, as well as some WD RE3's. I had a bunch of 1tb & 2TB's in RAID10's. I simplified a little this go-round with some 4TB's in simple mirrors. This go-round I tried some 4TB HGST 'Coolspin' 5300RPM drives, I got a stellar deal on 8 of them; which is half what I had in the system before. I've had very good luck with HGST drives. Speed is not crucial on this system, it's nothing more than a file server & local stream server. This cut the drive quantity in half; phasing out many 7200rpm RE3's. In the end, fewer drives = less power and twice the capacity.
                The new drives!
                NAS 2 (the backup server) got it first. This way I can dump NAS1 to this one and I know everything is current.
                Removed.
                New ones installed and now there's plenty of empty bays!
                ...and done!!
                The rest I can do from my office. The controller said HI!
                Arrays built, partitioned, and formatted.
                Most the night last night was spent transferring data over.....and now fast forward to this morning....
                NAS1's turn!
                Last 4 new drives.
                The pile!! I did reuse 2 of the 2tb Greens in a RAID1 for dedicated DVR drives....before it was all shared.
                Cleaned the filters while I had the doors open...
                ...and done! These all need to be wiped and the rehomed....
                ...and all finished... The transfer & resetting all the shares went smoother than usual for as many as there were.....Until next time with this jewel!!
                Team : 49813
                Join in!!
                Team Stats
                  Better than my 1.75TB 14 drive RAID 10 setup... made of 250GB 7200 Seagate's. Wanna talk about outdated bullpuckey
                  sigpic
                  (Insert witty quote here)
                    Topcat: Wrong last image in that post?
                    Permanently Retired Systems:
                    Kooky and Kool Systems
                    sigpic
                      Eh, having worked in data recovery, you were lucky with those Greens and also you said that you did clean the PCB contacts în them, which is likely what kept them running.
                      A working TV? How boring!
                        Originally posted by Th3_uN1Qu3 View Post
                        ...you said that you did clean the PCB contacts în them, which is likely what kept them running.
                        Seems you have to do that with any WD these days...
                        Team : 49813
                        Join in!!
                        Team Stats
