I bought this Westinghouse WD55UB4560 4K TV from an individual who don't wanted it fix the original problem it had was no video I check some voltages on the FRC board it wasn't sending voltage to the T-CON board so I replaced the FRC board that's giving this results split video. Any help to resolve will be greatly appreciated.
Westinghouse WD55UB4560 4K TV Now have split video
Re: Westinghouse WD55UB4560 4K TV Now have split video
Did you match the PCB assembly part number as printed on the white barcode sticker?Never stop learning
Guess you could try a firmware update, see if that works.Last edited by nomoresonys; 04-28-2021, 08:34 PM.
CV6M50L-A is the blank PCB part number, blank PCB can be stuffed to make many different PCBA'Ss
Shopjimmy: see the notes about matching the version number to the model number.
You can have same TV model with many difference version.
For examples:
https://www.shopjimmy.com/westinghou...w-04531-c050g/
https://www.shopjimmy.com/search.php...y=890-111-6M50
You can try contacting Shopjimmy.Never stop learning
Yes I think you have a mismatch, check the two frc boards here, the 2nd one down, see how it says match W16028-SY? And you do have that matching sticker number on your original frc board: https://www.ebay.com/sch/i.html?_fro...B4530&_sacat=0Last edited by nomoresonys; 05-02-2021, 05:32 AM.
The first two are both a match, the C/N numbers match too but they seem like a pretty steep price for a frc board.Last edited by nomoresonys; 05-02-2021, 05:32 AM.
