HP S2331 good ole 2-seconds-then-black
    Landlady came to my door because her computer wasn't working. Simple diagnosis - her monitor had died. It would show the picture for a moment then die. We replaced it with a much newer monitor but now I have the old one.
    Took it apart and replaced bulged capacitors with random used ones I had floating around. The capacities are a bit higher but I figured it would be OK? Guess not? Because it does the exact some thing.
    Is it doomed or should I try to find closer matching caps?
    Thanks.
    Re: HP S2331 good ole 2-seconds-then-black
    Well, this no longer matters, I accidentally knocked the monitor off my desk and the panel is smashed.
      Cap values would have probably been ok. Many times the 3-seconds-to-black is a dying CCFL tube drawing higher current and causing the shutdown....but since you kilt it with blunt force trauma, I suppose it's moot.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
