Trouble ID’ing C3 Cap.
  • Tommlynn49
    • Oct 2021
    • 3
    • Us
    This is a Jenn Air stove model # JMW8527 AAW. NO clock or temp. light.
    Disassembled and can see burn spot on one leg of the C3 cap. at the board hole. There is a resistor on that leg also. Only markings on the cap are: RGA105C and H245M. Can't seem to I'D as to the it's capacitance or voltage in order to order a new one. Any help would be greatly appreciated.
  • s675
    • Sep 2015
    • 35
    Re: Trouble ID'ing C3 Cap.
    Could be the Lelon RGA series.
    RGA = series
    105C = temp rating
    H245 = ?
    M = 20% tolerance
    Other Lelon RGA show things like H136 and H736.
    • s675
      • Sep 2015
      • 35
      Do you know the dimensions and lead pitch?
      • s675
        • Sep 2015
        • 35
        Here's the part number scheme I found. Doesn't seem to tell you anything.
        • R_J
          • 9528
          Post a picture, I suspect the value is marked on the other side of the capacitor, similar to this one.
          • Tommlynn49
            • Oct 2021
            • 3
            • Us
            Thanks everyone. This gives me some guidance. I haven’t de soldered and removed the unit yet. As suggested, it may be labeled on the side I can’t see as it’s mounted horizontally and only exposes the upper top portion. I failed to mention, it is a Lelon. Many thanks again.
            • tmcw
              Drying Oven - Preset Temp Fail
              by tmcw
              Here's an unusual one...
              This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
              It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
              However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
              01-21-2021, 03:11 AM
            • foshland
              MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
              by foshland
              Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
              Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
              External temperature (motherboard temp) is working OK, 27ºC more or less
              In windows, all the software I have tested shows correct the Core temps
              12-16-2023, 09:08 PM
            • mosfetratus
              concerning gtx675m vram temp
              by mosfetratus
              Is 98C vram temp are safe? Less demanding games goes 80ish.
              Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
              furmark goes about 104C, amperage keeps rising so do temps.
              01-30-2025, 08:41 AM
            • f-bone
              Having trouble with Fujitsu D2703-S BUP bios
              by f-bone
              Hi guys,
              I am having trouble finding a way to create a 512kb bin file from a fujitsu motherboard .BUP file.. I renamed it to zip but there are a few files in the I do not know how to combine to a .bin file.
              Please help.
              BR,
              george...
              03-15-2024, 05:20 AM
            • Opacky
              Nvidia gtx 950 memory chips order
              by Opacky
              Hello! I am trying to figure out order of memory banks on gtx 950 card. There are 4 chips in total, 2 in front and 2 on back side of card. Mods is giving me error on A0 and I am not sure which is that...i marked my idea what should be right order but if anyone can confirm or correct me that would be great. Thanks!...
              03-22-2022, 02:42 PM
