bios macbook a1278 820-3115-b
    hi . i need bios dump for macbook 820-3115-b
    thx
    OKBALORD
    Re: bios macbook a1278 820-3115-b
    not tested
      Thx bro i found the bios and it work fine 100%
      this is it
      OKBALORD
        thx
        Hi Share You A1278 820-3115-B Mac Os catalina Supported Firmware
          Hi I have tried all three dumps with a T866A programmer but unfortunately I have not been successful. If I do not uncheck "check id" option the flash does not start and if I uncheck it programming starts but after the first step it stops giving this error:
          Error! Code Address 0x000000 Buf_Val 0xFF IC_Val 0x00
          Can anyone helps me?
            check the contract between the chip pins and the programmer ... defective bios chip ..
              Thanks for you answer, the contact are ok. I'm trying to downgrade TL866A firmware, I read about problems with last firmware version. I'll let you know.
                Hi, I've downgraded firmware to 6.70 (I'have not found 6.71) but it have the same error. I'm going to buy new eeprom.
                  Hi, I give you an update. I bought a TL866II Plus and managed to flash the bios. I flashed the last posted, the one ready for catalina, everythings seems to be ok. Now I will try to install catalina.
                    Hi, everythigs ok. I would like to ask you if is possible to write the original serial number in the posted bin files. I've seen that after flashing the serial number is not the original. Thanks.
                      yes you can , use Hxd , find the SN LINE Than copy/paste
                        I will try, tnx
                          Thanks man
                            this is it
                            UMA BIOS! Great, working. Thanks for sharing.
                              thanks
                                bios help bios 820-3115-B
                                apple A1278 "820-3115-B"
                                hi everyone i received laptop and it has issue with original bios and i don't know if it was the original bin file or not because is was repaired in other place before
                                i'll attached the file which it was in damage BIOS , don't know the status is it the original bin file or not !!!!!!!!!!!!!
                                so please i need good bios bin file
                                A1278 "820-3115-B"
                                EMC :2554
                                SN:C1MPK2YBDV30
                                  and i have one question please
                                  SN is it include in the Bios Bin file with EMC or not ??????
                                  and also the attached file in my last post need clear my region or not
                                    bios clean me region a1278 "820-3115-B"
                                    bump
                                      Re: bios clean me region a1278 "820-3115-B"
                                      Originally posted by hazem3636 View Post
                                      bump
                                      try this
                                        hello
                                        please i need bios dump of macbook (A1278)
                                        sn: CPFL1GGQDTY3
                                        issue: no detect internal HDD (the HDD câble has been replaced)
                                        thk you
