I am looking for bios for dell latitude 3380
    Hi All
    does anyone have the bios for this dell latitude 3380
    keystone 13
    16824-1
    5kcrx
    many thanks
    Re: I am looking for bios for dell latitude 3380
    Originally posted by mgjini View Post
    Hi All
    keystone 13
    16824-1
    5kcrx
    many thanks
    Post here old bios and old bios error what?
      i am having trouble saving the old bios because it is The currently selected:GPR25L128A(ISP), capacity: 128Mbits, 16Mbytes. see also picture
      the laptop seems to have corrupted bios as i am having flashing light and fans spins than nothing than i get flashin lights between red and white
        You not need to select manually auto select chip this programmer.Id verification error
          this is the first chip that i haven not been able to read it
          022: >------------------------------------OK---------------------------------------<
          023: Using Mode-A to scan VGA port...
          024: Mode-A cannot identified the circuit board, change line sequence to Mode-D and continue to identifying...
          025: Mode-D cannot identified the circuit board, change line sequence to Mode-B and continue to identifying...
          026: Mode-B cannot identified the circuit board, change line sequence to Mode-C and continue to identifying...
          027: Scan SPI extension interface...
          028: Boot error, please check whether the EC chip is supplied voltage and ISP cable is connected properly or not. The ISP cable should not exceed 10cm in length.
          029: Chip is not recognized, please check whether the circuit board is powered on and ISP cable is connected properly or not. If all ok, it maybe the chip is damage.
            Try this file and post result
              i don't know how to write this chip, i am trying all the ones on the right as per my previous picture none will have it, all give error, does anyone know which one of the part number on this chip will take the bios, i also tried with a winbond chip but with that fan constantly on and high speed no dispaly
                If you open the bios from imranromi with UEFITool there`s 2 supported bios chips in the descriptor region.
                Flash chips in VSCC table:
                EF4018 (Winbond W25Q128)
                C22018 (Macronix MX25L128)
                EF4018 and C22018 are the JDEC id`s,you can google them.
                Winbond W25Q128FV , Macronix MX25L12805/12835/12845
                  hi, i just tried with winbond 25q128fvsg but nothing light on, i press the power button light on for 20 seconds no fan spin no getting warm processor, than light goes off
                    Thank you,
                    100% working
                      Originally posted by dahnking View Post
                      Thank you,
                      100% working
                      This file is working but taking too long to display
                      ANY HELP?
                        ANY HELP?
                        clean the ME firmware
                        https://winraid.level1techs.com/t/gu...lization/31277
                        https://www.badcaps.net/forum/showthread.php?t=88533
                          Dell Latitude 3380 with locked BIOS please help
                          i3-6006u
                          Code: 6S07LJZ-E7A8
                            i3-6006u
                            Code: 6S07LJZ-E7A8
                            Unlocker
                              latitude 3380
                              screen flash white , red, green etc.
                              here bios dump
                              can anyone check it for me.
                                try this one
                                  Originally posted by sebawilq View Post
                                  latitude 3380
                                  here bios dump
                                  re write the dump and soldered again
                                    Re: I am looking for bios for dell latitude 3380 clear me
                                      cleared and tested
                                        thanks
