Sony KDL-55EX640
    Sony KDL-55EX640
    This TV came with a defective LED, I fixed it, now is working but has a high frequency noise. When I touch a transformer leg (the yellow one on the right) the sound decreases.
    Re: Sony KDL-55EX640
    Have exact same tv with 3 bad LEDs. how did you fix edge LED strip ? replace LED or whole strip ? need part number of LED (5.7 volt).
    edge LED strip part # is LJ64-03374A - can't find them anywhere.
    My panel is #LJ96-05960A.
      Maybe that: https://www.ebay.com/itm/2pcs-New-55...-/274054349835
        I saw that earlier - but there out of stock. anyway of finding the actual LED part # 5.7 volt LED ? I can solder flow new ones on the strip.
          There are no part numbers for the individual LEDs. There are plenty of strips in China though, my search engine is full of vendors However not everything is being shipped currently due to Coronavirus.
          LEDs are identified by their size, colour temperature measured in Kelvin, voltage and current. Plenty of options to choose from on Aliexpress but again, Chinese shipping issues.
            https://www.ebay.com/itm/5-PCS-FOR-R...8AAOSwyd9dXX9~
            found these (in USA) - think they will work.
              They are 6 volt 7030, looks like a match.
                I replaced with another of the same size
                  Do you mean you replaced the led??
                    One thing to realize on this set is if the LEDS are bad - the set can act funny on startup and while running. This set would turn on, no video, and then after some time freeze up (video), then comeback on, and cycle several times until red indicator light comes on and blinks 6 times. Set would act as if shutting down and then rebooting.
