looking cv501 la-e891p rev 3.0 bios
    Re: Acer A315-53-317L
    Thanks friend, tested and working, I did not have to reprogram the kbc !!!
      Please Clean Me this bios A315-53-389V
      C5v01 la-e891p rev 3.0 2018-09-14
      a315-53-389v
      snid: 90503462834
      backup attached
        Re: Please Clean Me this bios A315-53-389V
        a315-53-389v
        snid: 90503462834
        backup attached
        bios extracted from the Acer site update.
        DMI 250000-251FFF
        KEYWIN 5A0000-5A003F
          DMI 250000-251FFF
          I tried but no display but the same as the old one that it will turn of minute. Where having a progress can you give me more
            Re: looking cv501 la-e891p rev 3.0 bios
            Originally posted by tribalcore20 View Post
            guys, can some one give me a clean bios of cv501 la-e891p rev 3.0?
            Model acer 3 a315-53
            Cant upload the old bin because it says invalid file
            thanks in advance
            we also need same file for that model above,,, hopefully you have,, thank you very much
              Acer Aspire 3 A315- Series Bios
              Hello Guys
              I need the following bios bin file:
              i3 7 Gen
              2018-06-15
              C5V01
              LA-E891P
              REV 2A
              Taking 0.14 Amps no display, before I drive myself mad I wanna be sure that the bios is sharp 100%
              Below is my original bios bin file
              Thank you
                Re: Acer Aspire 3 A315- Series Bios
                Originally posted by mnciks11 View Post
                Hello Guys
                i3 7 Gen
                2018-06-15
                C5V01
                LA-E891P
                REV 2A
                Thank you
                try post # 23, if it doesn't work post the full name of the laptop..the bios posted is not ok..don't write the bios chip until you make a correct copy of the bios chip, and check it with the HxD program ..
                  I noticed that the bios file is not okay
                    i3 7 Gen
                    2018-06-15
                    C5V01
                    LA-E891P
                    REV 2A
                    S/N: NXH2BEA00283300F3E3400
                    SNID: 83300390234
                      i3 7 gen
                      2018-06-15
                      c5v01
                      la-e891p
                      rev 2a
                      acer aspire 3 a315- series
                      s/n: Nxh2bea00283300f3e3400
                      snid: 83300390234
                      a315- ???
                        a315- ???
                        i3 7 Gen
                        2018-06-15
                        C5V01
                        LA-E891P
                        REV 2A
                        Acer Aspire 3 A315-38GM
                        SNID: 83300390234
                          try the bios from post # 23..it's ok for your laptop ..
                            It didn't work out
                              Dear, I need the BIOS for the Acer A315-53-3470 model, SNID 00377138195. I've tried several, but all without video. Plate C5V01 LA-E891P REV 3.0 2018-09-14.
                                post your old dump
                                  Need Bios Dump for Acer A315-53-314B
                                  Hi all!
                                  I'm looking for Acer A315-53-314B bios dump.
                                  motherboard: c5v01 la-e891p rev 3.0
                                  Attached is the current bios backup.
                                  Thanks in advance!
                                    Re: Need Bios Dump for Acer A315-53-314B
                                    Originally posted by anaximperator View Post
                                    Hi all!
                                    Thanks in advance!
                                    Try the one at post #23 .You can copy your DMI using the offsets given, if you know how to use a hex editor.
                                      Thank you! it worked!!!
                                        Hello, I have an Acer A315-53 laptop, SNID 85104251334, S/N NXH9KEB0048510A6113400, PLACA C5V01 LA-E891P REV 3.0, PLEASE I MISSED THE BIOS BIN, GREETINGS JOSE JAVIER
