Thank you to the guys at HEGE supporting Badcaps HEGE HEGE DEX Chart
Asus TP412FA
    Asus TP412FA
    please help me need ASUS tp412fa bios
    don't have original file my programmer cant see flash
    need file please board number tp412fa mini board rev 2.1
    thanks
    Re: asus tp412fa bios
    thanks
    What model is your programmer ?
      mini pro tl866cs
      i need file then will replace bios ic
        Asus TP412FA
        Need Help remove this bios password, i've try remove 1 password that i think it admin, but only user password.
        Thanks before
          Re: Asus TP412FA
          Its an AMI bios, the AMITSE method will work on this. https://gist.github.com/en4rab/55088...f3039e3c8ab6fd
          Its been mentioned on the forum many times how to decrypt.Open the bios with a hex editor,search for AMITSE ,keep searching again until you find an AMITSE area with some code.Copy the hex and make it the same length as the decyption hex ,XOR both codes to ASCII
          Copy the first line of hex into notepad/wordpad ,remove the spaces.
          This is the second code to decrypt the first
          5B93B62611BA6C4DC7E022747D07D89A332E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83 <- remove space between F and 7
          Enter both hex codes at http://xor.pw ,output to ASCII
            Re: Asus TP412FA
            Ah thanks for your info, i already find something usefull info before i make this post. Maybe i don't see about that. Really thanks for help sir
              Re: Asus TP412FA
              OMG ... I have tried to understand that in the past ... I was looking at it like a goat THX SMDFLEA such a easy explanation !
                Asus TP412FA
                hello i have an Asus TP412FA with no power on , maybe bios corrupted any have bios in order to try this in first try. Maybe it's the ec?
                thanks
                  Re: Asus TP412FA
                  thanks
                  Give me the sn from the unit
                    Re: Asus TP412FA
                    hi pn is tp412fa-ec143r and sn is kcn0lp00e24750a
                      Re: Asus TP412FA
                      see the original bios
                        Re: Asus TP412FA
                        Sorry for the late respond but here it is
                          Re: Asus TP412FA
                          i read my bios with hexeditor i see stranger thing
                            Re: Asus TP412FA
                            hi i flash the bios , and same thing no power on
                              Re: Asus TP412FA
                              This is F1 bios. You have other problem its not the bios.
                                Re: Asus TP412FA
                                yes other mistake , i must open a new post
                                  Re: Asus TP412FA
                                  its works
                                    Asus Vivobook Flip 14 TP412FA clean BIOS need
                                    Hi, I lost the BIOS password of my ASUS laptop, I can read and write BIOS files with a programmer, how to unlock it? Thanks a lot for the help!
                                    TP412FAC Rev. 2.0
                                      Re: Asus Vivobook Flip 14 TP412FA clean BIOS need
                                      TP412FAC Rev. 2.0
                                      Admin Password : 8328
                                      Boot Password : 7fjp89bm
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                        Thank you, problem solved
