La-6842p rev 1.0 ec bios needed
    Toshiba C660-14W
    Mb. number:
    PWWAA LA-6842P rev.1.0
    Bios & EC flash BIN
    The content of the uploaded file:
    *C660-14w "save" Main bios.bin
    *ec flash c660-14w "save".bin
    *BIOS0 Cutted main.file
    -The "save" label files are saved from original BIOS ic and Ec flash ic.
    -BIOS0 is downloaded from toshiba website and cutted to right size.
    i need ec bios and bios file i have two laptops with a problem of boot. when i put usb key it stay stored in memry even it's not plugged, i can see it in the boot menu.
    monterborad: la-6842p rev 1.0
      Re: La-6842p rev 1.0 ec bios needed
      Here you go
        thankyoun so much i will try this
          thanks for bios file and ec file but the laptop shutdown it self every 30 sec;
          can someone clear the intel Me for me,
          thanks
            here it is with clean me
            Im Back... sort of...
              thankyou MR ala_borbe, i will try it and give the feed back.
                with the clean bios, the laptop power on no display then power off it self
                the time is less than 30 sec.
                i recheck with the first bios it display but same problem off after 30 sec.
                i have two motherboard with the same problem.
                  ok, try this
                    ok, try this
                    thanks the bios is tested in another board and it's ok, i think i have another problem.
                    thankyou again for your time. i know you are always busy.
                      maybe unsupported cpu? try another one
                      np, im glad to help whenever i can
                        Re: Toshiba C660-14W LA-6842P rev.1.0 bios/ec flash dump Tested
                        thx you are the best
                          thankuu for clean me bios
                            toshiba satellite c660-A206 LA-6842P Bios needed
                            hi all members
                            i seek a dump for toshiba satellite c660-A206
                            Core I3
                            PART NO .PSC0SV
                            SERIAL NO.1C124042K
                            the motherboard is :
                            PWWAA LA-6842P
                            REV: 1.0
                            2010-08-26
                            thanks
                              Re: toshiba satellite c660-A206 Bios needed
                              Try This
                                many thanks mr .mcplslg123
                                i try it and reply soon as possible
                                hoping to working for me
                                  lader mr .mcplslg123 not working for me
                                  perhaps is different in PART NO .PSC0SV
                                    here is your bios
                                    clean me
                                    id you need ec also read old and post here i will update it
                                      many thanks mr .ala_borbe
                                        thanks so much
