Hp probook 640 g1 bios
    Re: HELP BIOS HP 640 G1 corrupt
    Originally posted by Vesko356 View Post
    You must post the serial number.
    Read the rules before posting:
    Sorry, here is the serial: 5CG4384S7M
      Originally posted by profiler View Post
      I have exact the same problem. I tried to replace the ME Region.bin and reflash the modified outimage, but it does not change anything.
      Model: HP Probook 640 G1
      Mainboard: 6050A2566302-MB-A03
      Extracted BIOS and board images are attached.
      Thanks for help!
      Use this it works i already tested.
        Hi rex98, thank you for the answer. I tried your BIOS, but the behavior keeps the same.
          Re: Hp probook 640 g1 bios
          Maybe this is not a problem with the BIOS? A year ago I got this notebook and it had the problem described here. After cleaning the ME region, it suddenly works again. But after a few months it stopped working and the same problem like now appears. I had no time to fix it and leave it in this state until now. I resoldered my cable to the flash chip and readout and flashing incl. verifying works. So I tried the same procedure like that time but now I can't get it working again. Are there any other reason why caps lock is blinking 5 times followed by high speed CPU fan? I have read that this is happening when the embedded controller does not get the BIOS POST message within a certain time. So does this mean that it can't have anything to do with some power rails? The flash chip is getting 3.3V at VCC.
            HP Probook 640 G1 BIOS Need
            Board id: 6050A2566402 MB A03
            Serial: 5CG4340VDB
            PCID: A3009DD10303
            Product: D9R52AV
            Need bios. Please help.
              Hi Everyone,
              My BIOS is corrupted. Laptop powers up but there is no picture.
              Could you please help and repair my attached bios dump?
              Thank you for your help!
                Originally posted by szakacsa195 View Post
                Hi Everyone,
                RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                https://www.badcaps.net/forum/troubl...before-posting .
                You MUST:
                  You MUST:
                  Thanks for the note.
                  Model: HP ProBook 640 G1
                  Serial: 5CG43424GP
                  Board No.: 6050A2566302-MB-A03
                  Faulty Bios dump: attached
                    SMDFlea commented
                    Editing a comment
                    bios already posted at 276 ,no need to post it again
                  Serial: 5CG43424GP
                  HP ProBook 640 G1 Notebook PC
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Thanks for your help. Tested the new BIOS and machine turns on with display. However got the following error message:
                    What's wrong?
                      bump. Post 279
                        What's wrong?
                        You just need to restore DMI. I don't have DMI for this device so I borrowed from other devices, only the serial number and product are yours.
                          With this new dump there is no picture after powering up. Problem is the same as with the original bios dump.
                          Any idea?
                          Thanks for your help!
                          • CammyTier1
                            CammyTier1 commented
                            Editing a comment
                            If your original does the same then more then likely u had a bad read or the og bios was already bad. do you get any power atall like fans spinning ect ?
                          What's wrong?
                          Try Fix !!
                            Originally posted by minhdigital View Post
                            Try Fix !!
                            Well it is much better then before, but there are still some missing information. Product family and System Board CT number are missing if I understand well.
                            Entered into BIOS and find the following informations.
                            How can I update the missing informations as well?
                              try this and replay
                                Originally posted by almussafer View Post
                                try this and replay
                                Now the machine powers up without error message, but every motherboard specific information are incorrect. Serial, SKU, system info, etc... How can I restore my original data?
                                  Last edited by szakacsa195; 12-15-2023, 01:53 PM. Reason: Another interesting thing: it shows Probook 650 G1 instead of 640 G1. :(
                                      please try this and report
