Hello all reading this post. I have an Ocosmo E32 TV and have isolated the backlight problem to one defective LED. Testing the good LED strips I have found that each LED drops about 3.0VDC across it. Also from reading and using my DVM each LED draws about 350mA of current. My unit has 7 LEDS on each strip with a total of 21 LEDS. Guessing from this the series supply voltage should be 66 VDC. I have removed the defective LED from the LED strip and using my micrometer I'm getting a 3.5mm x 2.8mm layout. Would this be defined as a 3528 LED SMT? The next question what temperature is this LED 6000K? Is it cool white?
Where can I get just the SMT LED to fix the LED strip?
Attaching Photos of Device and removed LED from strip.
