So this was a great find! $2 at the thrift store, since it was un-tested. I brought it home and tested it out and it worked just fine. However, I wanted to take it apart to replace the caps. There isn't a lot of room so I had to order some fresh caps for it. I loved how easy this thing was to take apart. Very easy!
What was most noticeable was the main board! Look at how it was installed, it is completely warped because they did not place it under the notch to keep it in place. Fortunately, it does not have any SMD components where the bend it. What it did, was start desoldering the VGA mount. What I was curious about was, should I just resolder the flexed joints and install it as it was? I'm afraid that if I try and bent it back, it would break. It does not want to flex and is firmly in its current position.
The board is very simple. The original caps would probably last a long time but they will be replaced anyways
'SMEAR GLUE'
'SMEAR GLUE'
