P2317H not turning on
    Re: P2317H not turning on
    Originally posted by R_J View Post
    It could be flashing for many reasons, no input signal, no backlights etc.
    >Goto #6
    I have to wait for a few days before i get the working power supply. In the meantime i was thinking. What if i test our theory by doing the following.
    Connect the two boards and also connect my lab power supply to 5v line where its low and let it draw the power from there when its plugged?
    I think it could provide a solution for our theory does it not?
      After hooking up the powersupply to the 5v with the main boards connected and plugged in, the voltage is still waving and goes up only to about 2.9v, maybe the two small electrolit capacitors on the mainboard are bad and cannot hold charge? Ordered an ESR meter for that (will be good for other things as well)
      Let you know when power supply board changed and what ESR meter sees.
        Got a new powerboard and it powers up fine, BUT...
        The picture on the panel is scrambled
        Plugged back and original panel picture and it fine with my board, so my LCD panel is bad also.
        Removed the panel back tape and LCD panel number is:
        M230F07V01_HF REV 0.0
        - Checked that board and no short to ground
        - No bad diode found
        - Fuse is ok
        Anyone can help diagnosing if it can be repaired?
        2 IC THAT IS on the board is sm4142 and lfm60a3
        reading after powered on:
        VON: 27,9V
        VSS1: 8,4 V
        VSS2: 9,8 V
        TVDD18: 1.8V
        TVDD12: 1.2V
        DVDD: 1,8 V
        AVDD: 10,42
        VCC: 5.08V
        D2P1 0,58 V
        D2N1 0,58 V
        HCT3 4,17 V
        VCST_S3 4,06 V
        CN3R_1 0,020mV
        CN3R_2 0,020V
        SCL: 5V
        RVC 4,6v
        CVC 1.03V
        R1 0.262
        RDV1 10V
        RDV2 4V
        CREF 4V
          After ESR meter is arriving I think i will try with this to solve the problem:
          https://www.youtube.com/watch?v=4HFHpzSQfj0
