hp stream 14-cb161wm
    machine nolonger displays and caps blinking 5 times with 2short quick beeps
    Re: hp stream 14-cb161wm
    Your backup shows up as HP Stream Laptop 11-ak0xxx serial 5CD041P8MJ, is this correct? Your thread is for a stream 14 cb series.
      its hp stream laptop model 14-cb161wm serial 5cd9287633 rmn:tpn-q183
        let me get you a new backup
          Try it now
            same results. caps blinking 5 times with 2 short quick beeps
              according to the name and model posted, this is the bios of the laptop...the posted bios is something else...I think you confused them..try this..
                Yep, that's the file I used, just added his DMI and winkeys. Check voltages, if any small caps/resistors shifted when desoldering, reflow if needed. Also verify that the new bios is really flashed by reading it off again and comparing, takes a couple of minutes more.
                  Have nodisplay...not yet solved
