Your dump is bigger of couple bytes ,, try to save it one more time ... here is another dump to try
Thanks a lot for pointing that out to me.You are right.Well if that is the case that is the only backup i had taken.So chances of getting the original backup will not be possible because i have already erase the chip.I will try that dump you sent and see how it goes. thanks
Well to be honest bigger is always better even in BIOS dump But it may be some problem with reading ... so always do 2x reading and compare the files ...
Okay just flashed the bios you posted and i get picture now.Only thing i notice is I get a critical low battery logo coming up on screen whether i have the labtop battery plugged in or not . And it's not charging the battery apparently. So thanks for the working bios.I will post my other issue in another forum section. Thanks again.
Well I can try to rebuild your BIOS If the issue is not in BIOS but I doubt that ... it could be charging IC. Not sure ...
Still with the dump that U have now U are going to missed information regarding the model, serial ...etc. ,, U can edited the BIN and find all the information in your dump ...
Offset starting from 0x520003 till 0x520101
I have attached updated info in BIOS dump.
thanks a million my friend.Bios is working 100% fine now.
