Lenovo x270 bios+ec
    Re: Lenovo x270 bios+ec
    Originally posted by destroyer15ic View Post
    hello sir, need bios remove password for this model, many thanks
    You can unlock it yourself with the Autopatcher
    https://www.badcaps.net/forum/showpo...52&postcount=1
      sir, sorry but i can not follow the procedure will be glad if you help me many thanks
        Try this ....
          sir, this work but on doing the procedure the unit stucks on (entering set up)
            should i flash again with the original backup?
              its done guys thanks so much for the help... thumbs up!!!
                am un lenovo x270 si am uitat parola de pe bios
                I have a lenovo x270 and I forgot the password on the bios
                  https://www.badcaps.net/forum/showthread.php?t=87588
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Try this ...
                        plese remove BIOS password
                          read post #48..
                            Originally posted by peste View Post
                            read post #48..
                            patch don't works
                              please help
                                please help
                                Here
                                  can you fix my bios, no display issue. ihve try all dump bios x270 but cant working. DX270 NM-B061 Rev 1.0 Sn: SN20L82612. thx
                                    hello friends
                                    can you unlock my bios lenovo x270
                                      Hi, can someone help me repair this BIOS? The laptop only blinks the power button three times but doesn't want to power on, no fan spin either, this seemingly happened after a BIOS flash over Windows Update...
                                      thanks!
                                        thanks!
                                        Sorry for doubleposting, I couldn't find a way to edit...
                                        I flashed an ME cleaned BIOS image to the laptop and it works as normal, even boots fine after reboots, but a full power off and power on makes the power button LED remain lit for three seconds and then shut down...
                                        I waited up to 10 minutes just in case but it wouldn't come back up, I had to take out the CMOS battery and turn it on again, just to have the same issue after turning off the laptop if I left the CMOS battery plugged in
                                        I tried patching the dump I had made earlier with a healthy BIOS region but it just made UEFITool crash and catch on fire
                                        Is there a way to rebuild the flash image with information I can get from inside Windows/Linux? I kinda don't have that much budget to invest in an EC programmer
                                          Here
