A1708 820-00840-a efi lock
    Re: A1708 820-00840-a efi lock
    Hello, can you help me to unlock this ?
      try..
        Thanks but not working. Fan spinning, no chime, no display.
          try..
            Still not working.
              Still not working.
              use the clip ?? you may not have written the correct chip ...
                U6100 with TL866II+
                  U6100 with TL866II+
                  you didn't understand ... did you use the clip from the programmer ?? or did you remove the chip from the motherboard, before you wrote the bios chip ?? did you not write another physical chip, but it was written with errors for certain reasons..how did you proceed to read and write the bios chip ??
                    I removed the chip U6100 (MX25L6473E) from the board. Read and Write this chip using Xgpro software chip MX25L6473E selected.
                    No read or write error.
                      ok ... and the bios posted in post # 82 is the original laptop? it works with it but it has the password ??? try it again and see what happens ..
                        Thank you for your time.
                        I took your file from post #21, clean ME and change SN, everything OK.
                          Hi! I have 840-00840-01 board. Does anyone have a bios file for this board? ME analyzer shows ME version: 11.8.86.3877
                            Model A1708 EMC 3164 820-00840-A
                            Hi guys please send password plz Model A1708 EMC 3164 820-00840-A attached my original dump
                              Re: Model A1708 EMC 3164 820-00840-A
                              try..
                                thank you very much everything is ok
                                  Anyone can help me with A1708 820-00840-a efi lock? Need to remove the efi lock. I have attached my bios file.
                                    try..
                                      thanks. it worked, but the MB won't wake from sleep, pls what can i do
                                        reset PRAM
                                          done PRAM reset, still not waking from sleep either by closing the lid or allowing it to sleep its self.. it wount wake
