unlock password on thinkpad x260
    Re: unlock password on thinkpad x260
    Originally posted by qayyum786 View Post
    did you try WITH FLASH bios from another dump ?
    read this post if you have administrator password
    https://www.badcaps.net/forum/showthread.php?t=87588
    i already try this, but i got 5x2 beep and off
      is it administrator password ?
        yes
          try this given bios write the bios and check if you will not get any beep sound than you are good to go for below given steps
          STEP 1: Flash Given PATCHED Bios
          STEP 2: Boot the machine
          STEP 3: Press ENTER/F1/ to enter BIOS settings
          STEP 4: Enter 1234 when asked for Supervisor Password
          STEP 5: Press enter when it shows Hardware ID
          STEP 6: Press space bar 2x when asked
          STEP 7: Turn off machine
          {Now 1st part is complete }
          STEP 8: now You Have To Remove the bios chip & write your old original backup bios (x260.rar)
          STEP 9:Start Laptop Go to bios setting by pressing F1 & Reset BIOS settings to factory default save and exit
            thank you
              so many thanks * qayyum786 * it's working well.very thanks your help.
                so many thanks*qayyum786* it's work well.very thanks
                  Can someone add patch fo password removal for this bios dump? Its from x240 with i7, board NM-A091 rev1.0.
                    Here is your patched file, follow instructions on #20.
                    For search purposes, it is recommended that next time you open a new thread if asking for password, this one is for x260, not x240.
                    By the way, both the original files are the same, good job on making at least two, they are extremely important.
                      Thanks you for your reply and forgive me for posting in this thread regarding different laptop model. Unfortunately after fallowing instructions and flashing original bios file laptop doesn't turn on, it just flashes 3 times with power button and backlight keyboard flashes one time. Nothing happens other than that.
                        Did you desolder in order to read chip? Then solder it back with the patched file? If so, resolder chip, I myself use hot air then the iron tip just to make sure the legs are fully seated. It happened to me twice on two X250, there was a lot of lead (not needed) under the Bios chip. I just took it all off.
                        By the way, I have had bad luck with reading chips with the wired clips, I don't trust them.
                          I tried desoldering chip and soldering in programmer and to my suprise it worked. Laptop is turning on and the password is removed. Before I tried with clip, I checked couple of times if writing was correct and everything was, so I don't know why that happend.Thank you very much for your help.
                            thinkpad x260 unlock
                            please help me to patch bios for thinkpad x260
                              Re: thinkpad x260 unlock
                              This isn`t the bios requests forum
                                Uh, moved just after you replied…
                                  please help me to patch locked bios thinkpad x260
                                    STEP 1: Flash and replace current BIOS with the generated patch file
                                    STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                    STEP 4: Enter any character when asked for Supervisor Password
                                    STEP 8: Restore original BIOS
                                    STEP 9: Reset BIOS settings to factory defaulT
                                      it works but it blocked on the start screen
                                        thanks its work
                                          Hi all
                                          someone can help me to remove biospwd from this lenovo x260 NMA581. I used
                                          lenovo autopatcher 0.2 but it give 5beepx2. I don't know what's happened because
                                          I made as tutorial said.
                                          I'll attach the two dump (origin and patched)
                                          Thanks in advance
