Micronta Talking Alarm Clock Full Recap
    My grandfather had this Micronta VoxClock3 digital alarm clock that just had random digits displayed when you plugged it in and just overall acted crazy. Opened her up last night and found every single cap either completely open or ESR in the 50 ohm range. All caps replaced but waiting on a .47uf 50v cap to arrive as I didn't have any.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Micronta Talking Alarm Clock Full Recap
    .47? use a polyester cap - 470n
      I don't have any of those lying around either. Need to invest in a polyester assortment.
      Ryzen 3600x
      FX-8802 Iron
        well even 1uf electrolytic caps are being phased out because film caps are small enough to replace them.
        what chips are in that clock?
        spo250? spo256? texas tms5110??
          My pic is out of focus, I'll check soon
          Ryzen 3600x
          FX-8802 Iron
            Here you go. Probably late 80's early 90's by the date codes on chips.
            Ryzen 3600x
            FX-8802 Iron
              It came out in 1986? https://www.radioshackcatalogs.com
                nice, i wonder if the sample rom has been dumped!
                  TMS5110 speech synthesizer was in TI Speak & Spell, it used LPC linear-predictive coding. I think it had better speech quality than SPO256 allophones.
                  It looks like it could use a 1-bit or 4-bit databus to read ROMs. One IC must be the main MCU and another ROM.
                  TMS5110AN2L-1
                  MP1343
                  CM72010NL
                    it uses a custom databus for the roms - there are replacement projects online.
                      Got the new .47 cap today and installed. Powered up without the daughter board even being re-soldered back in and it's working great! good crisp digits, no funny business. I'll post later on once I have it fully back together.
                      Ryzen 3600x
                      FX-8802 Iron
                        All done, working great.
                        Ryzen 3600x
                        FX-8802 Iron
                          good fix! yet another happy old folk! this past year has been bad for them. good to fix their stuff for them and make them happy again! thats if u are fixing it for them to return it to them and not if u get to keep it if u fix it...
                            i like the colour, that's done using red leds behind a purple filter isnt it?
                              I need a video or sound snip to hear what it sounds like
                              In the 80's many red LED displays were behind a purple filter. I think it works much better for contrast (compared to red).
                              edit: youtube versions are crap https://www.youtube.com/results?search_query=voxclock
                                Am I right in thinking that failing caps is a relatively rare phenomenon with this particular clock? O, rather, is this a widely-known problem with the VC 3 and most owners simply choose to bin their clock rather than taking the time and trouble to repair it?
                                (I ask because I was quite surprised to find a mere single mention of this nearly forty-year-old clock on the forum. Perhaps my sense of surprise is misplaced?)
                                  Capacitors have limited lifetime and people tend to throw away clocks after they...get their cell phones?
                                    I have this clock back in my possession. My grandfather claims it still acts weird after some time. I'll take it apart and give it a closer inspection for cracked solder joints.
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      not enough info,
                                      you should have asked if he meant the display or the speech
                                        Can you please ask your grandfather whether the clock kept accurate time until recently?
                                        I ask because, rather than using the 60 Hertz mains to maintain accuracy, this particular clock relies on the MCU frequency; I am not clear on why the manufacturer would do this (perhaps someone here knows?). However, I am informed this is not an accurate way to keep the clock synced when using the simple RC oscillator the clock was designed with.
                                        (I know of no one else who owns one of these, so I hope you will not mind my asking.)
