[TUTORIAL] fix asus bios with bios from asus web support
    Re: [TUTORIAL] fix asus bios winh bios from asus web support
    Great tutorial ,nice job..thank you
      Re: [TUTORIAL] fix asus bios with bios from asus web support
      thanks
        Thank you sir
          How to make or rebuild bios with amd processor sir ?
            use only first 3 steps
            Im Back... sort of...
              Thanks a lot!!! Restored ASUS X542UA(M/B X542UQ Rev2.0) laptop, it locked bios admin password.
                good jobe bro
                  many many thanks
                    Thank you very much
                      thanks
                      Mohammed Mohan
                        thank you very much
                          Good Job! Thanks
                            This is very good honestly. Thumbs up
                              TankYou!! 10
                                thank you so much that was very helpful, god bless you
                                  thanks
                                    hi . im using this trick for a while withe all laptops models acer lenovo hp asus dell ...etc its work fine only make sure that the bios rgn extracted from the update is same size with the original bios rgn .
                                      Moderator edit: The razor_amd guide has been split off into a new thread -> https://www.badcaps.net/forum/showthread.php?t=96604
                                        hm, thank you for kindly sharing your methond... very usefull
                                        anyway, i intended to cover other brands with tutorials (toshiba, acer, hp is very nasty, sometimes bios from web update are encrypted and i found 3 differen methods that work)
                                        but stuff in life happened and im not in industry anymore, although im keeping an eye on forum it has grown on me
                                        just as remark, maybe you should repost and make sticky so that it can be found easyer by other people since you have done such a wonderful job...
                                        anyway, sorry for OT and keep up the good work mate
                                          No problem, I found very useful info here and this is my way of repaying. It took me a while to make this tutorial but I am glad I did.
                                          Anyway, this method can be used on all notebooks, not just ASUS, with others you just have to know what to look for inside BIOS Region. With HP there are BID's (BIOS ID), search it with Hex app and check which BIOS ID you have and need. Sometimes when extracting exe files from manufacturer website you will get only BIOS Region, sometimes ME Region as well with it in separate file and often there will be whole BIOS images. HP has ME regions in firmware section on their website, and I use those (newer) images when I build new BIOS.
                                          For Acer it is mandatory to copy DMI, they wouldn't give image on screen if missing DMI data in BIOS Region. Toshiba is easy, maybe the easiest.
                                          Lenovo can be tricky, but you often get everything in 1 file. I have written the tutorial on another website but pictures are gone . I wanted to re-post here but I have to do it again someday...
