Re: Asus X555L backlight shuts off when on battery
I had the same problem with an Asus X555L notebook- it works fine on AC, but the backlight turns off when I disconnect AC, even in the BIOS.
I updated BIOS, etc, then read about the back light coil on the PCB attached to the actual panel, on this or a similar post, on this forum.
I didn't have the correct replacement coils, and I figured they should either work or not work, so I ended up putting flux over the area/chips around the coil, then heated the whole area - being careful to cover plastic parts and other heat sensitive parts first with thick foil.
Tested - and its working fine so far.
I suspect poor solder caused the issue.
Hi guys ! I am new here and i have a X553M that hase the same problem.
I have a donnor laptop (X553M) with a crack screen but i was wondering if swapping the PCB from the donnor screen to the main laptop screen could solve the problem ?
Is it easily doable ?
Thanks !
Originally posted by joshAU View PostI had the same problem with an Asus X555L notebook- it works fine on AC, but the backlight turns off when I disconnect AC, even in the BIOS.
Thanks for the info tho !
Originally posted by Unitekinfo View PostHi guys ! I am new here and i have a X553M that hase the same problem.
Thanks !Last edited by Dannyx; 08-25-2021, 10:59 AM.Wattevah...
Originally posted by Dannyx View PostAFAIK, it's impossible to separate the PCB from the panel itself in laptop LCDs because the flex cables connecting the board to the display panel are permanently bonded at the factory. You only option is to either replace the coil or the entire display.
Originally posted by Unitekinfo View PostThanks a bunch i will try to swap the coils !Wattevah...
Originally posted by Dannyx View PostJust be careful not to destroy the display or the flex cables, as I'm not entirely sure where that coil is located. Why don't you post a pic while you're at it ?
