dell 15-7577, LA-E991P bios file fix
    i attached my dump for fix... with this original file the unit won't turn on..
    model: CKA50/CKF50 LA-E991P REV:1.0(A00)
    THANKS
    Re: dell 15-7577, LA-E991P bios file fix
    Try this one with clean ME.
      same problem,
      thanks for you support
        Another for you to try,extracted from dell bios update.
          Hi guys. I am looking for a dump for MEC1416 for this board.
            SMDFlea please tell me, what program do you use to extract this bios from update. I've have used a Dell extractor tool but on this neewer updates its not working
              Its not easy with newer dell bios. You need to use python script. Dont ask me how
                I got an image with this file. only the image is too late and the fan speed is too high. I haven't tried to make me region myself, can you help me?
                  try..
                    Originally posted by peste View Post
                    try..
                    no image.
                      try..
                      Your bios is missing the OEM Public Key Hash and Key Manifest ID .
                        Must have forgot to clean the ME firmware,can`t remember it was over a year ago
                        no image.
                        Try this one
                          Try this one
                          Didn't give an image, man. It resets a few times and then pulls off at 1.23A. and the next time I want to turn it on, it takes 30-40 seconds. When I turn it on, it pulls 1.23A and closes again.
                          Original Backup Rom
                            Originally posted by prosis View Post
                            didn't give an image, man. It resets a few times and then pulls off at 1.23a. And the next time i want to turn it on, it takes 30-40 seconds. When i turn it on, it pulls 1.23a and closes again.
                            original backup rom
                            try & report
                              Original Backup Rom
                              try..
                                Originally posted by qayyum786 View Post
                                try & report
                                I got an image. There are only a few problems.
                                When the device displays an image, it displays as "manufacturing mode on alt + F".
                                When I switch to normal mode with Alt + F, the image disappears and does not return.
                                When I enter and save the "service tag" information by logging into the bios, it does not display any more and it turns off after a few seconds, pulling around 1.10A.
                                  Its required to fill dmi information
                                  you can try this with dmi info
                                    situation does not display when adding the same "service tag" information and restarting.
                                      Where can I get DMI information and how can I add it?
                                        TRY to edit from post 13 your backup you may try now
